Recently, some grass files that were on my computer were accidentally
deleted - I recovered them from backup but it seems that maybe not all.
When I open grass and load up a raster with d.rast the map does not appear
and I get the following error message:
WARNING: Raster map <toc10@toc@toc>: format field in header file invalid
WARNING: Unable to open raster map <toc10@toc@toc>
ERROR: Unable to open raster map <toc10@toc>
Does anyone know what might be missing? And if there is a fix to this?
It seems to have happened to all of the rasters that I have in that
project!
The first point:
Typing the comnand:
d.rast map=xxxx
you don't load the file. You just display the already imported map from existing mapset
So be sure you files are imported to the current mapset
You may check this by the command:
d.list rast (maybe some differences in syntax depending on grass version)
Second: check the projection in your workspace and imported files
Hope it helps
Best regards,
Maria V. Kozlova
š /------------------------------------\
š Information System Lab. (ISysLab)
š State Oceanographic Institute,
š Kropotkinsky per., 6,
š MOSCOW, 119034,
š RUSSIA
š ------------------------------------
š tel. š š+7 499 246 6448
š fax. š š+7 499 246 7288
š mailto: škclo@yandex.ruš
š \------------------------------------/
project!
This double @ is a bit fishy.
Can you check where it comes from?
ERROR: Unable to open raster map toc10@toc
Hi Maria, thank you. Yes, the rasters are there - they are listed with
g.listŠ.
Projection is all ok too.
MmmmŠ.
On 11/09/2015 4:27 pm, "Kozlova Maria" <kclo@yandex.ru> wrote:
Hi, Rafael,
The first point:
Typing the comnand:
d.rast map=xxxx
existing mapset
Hope it helps
Best regards,
Maria V. Kozlova
MOSCOW, 119034,
RUSSIA
tel. +7 499 246 6448
fax. +7 499 246 7288
mailto: kclo@yandex.ru
appear
project!
Hi Markus,
Yes…not sure where the double @ comes from – it just displays this in the error message…
I looked at the files in the cellhd folder (which I assume are the header files) and they seem fine:
On 11/09/15 09:27, Raphael.Viscarra-Rossel@csiro.au wrote:
Hi Markus,
the error message…
proj: 3
zone: 0
north: 9:59:50.99856S
south: 43:38:32.993713S
east: 153:38:23.977878E
west: 112:54:41.983744E
cols: 48874
rows: 40374
e-w resol: 0:00:03
n-s resol: 0:00:03
format: -1
compressed: 1
This looks fine.
The error message you cited was:
but the format field in the header looks ok (-1 => FP map).
What does r.info tell you on the file ?
What about launching 'd.mon wx0' + 'd.rast toc10' from the command line ?
You can also try copying the raster file to a different name with g.copy.
Another option would be to make your location (or an extract) available somewhere so that we can have a look.
Thank you for the suggestions. r.info returns the following
WARNING: can't read range file for [toc10 in toc]
ERROR: Unable to read range file
The frange file I found seems to be there but it is not readable.
I am beginning to thing that whatever I deleted was not recovered and that
I will need to read the data back into grassŠ
What a pain!
Thank you all for your suggestions.
On 11/09/2015 6:00 pm, "Moritz Lennert" <mlennert@club.worldonline.be>
Hi Markus,
YesŠnot sure where the double @ comes from it just displays this in
the error messageŠ
proj: 3
zone: 0
cols: 48874
rows: 40374
e-w resol: 0:00:03
n-s resol: 0:00:03
format: -1
compressed: 1
This looks fine.
invalid
