[GRASS-user] Warnings while importing Kompsat-2 images
Hi there
I imported Kompsat-2 images using r.in.gdal and I gfot this warnings:
rning 1: TIFFFetchNormalTag:ASCII value for tag
“DocumentName” does not end in null byte
Warning 1: TIFFFetchNormalTag:ASCII value for tag
“ImageDescription” does not end in null byte
Warning 1: TIFFFetchNormalTag:ASCII value for tag “Artist”
“HostComputer” does not end in null byte
Projection of input dataset and current location appear to match
What is the origin of this? Or what can I do to avoid this? Kompsat-2 images are followed by an header txt. can that be useful?
Because it has recognized projection, the resolution is the same and even nº of cols/rows.
Thanks
Luis
