running r.sun on a mountain area with time=8 and day=1, I got negative values for the diffuse radiation fraction.
I even get negative global radiation!
Where am I wrong?
| Layer: 1_8_d Date: Fri Oct 12 07:53:50 2007 |
| Mapset: zodoardo Login of Creator: zodoardo |
| DataBase: //media/sda7/zodoardo/cartografia/grassdb |
| Title: ( r.sun solar model output ) |
timestamp: none |
Type of Map: raster Number of Categories: 255 |
Data Type: FCELL |
Rows: 864 |
Columns: 1290 |
Total Cells: 1114560 |
Projection: UTM (zone 32) |
N: 5096987.5 S: 5032187.5 Res: 75 |
E: 422587.5 W: 325837.5 Res: 75 |
Range of data: min = -18.926418 max = 53.797997 |
Data Source: |
Data Description: |
generated by r.sun |
Comments: |
Day [1-365]: 1 |
Local (solar) time (decimal hr.): 8.0000 |
Solar constant (W/m^2): 1367 |
Extraterrestrial irradiance (W/m^2): 1412.689562 |
Declination (rad): -0.401581 |
Latitude min-max(deg): 45.4214 - 46.0199 |
Sunrise time (hr.): 7.74 |
Sunset time (hr.): 16.26 |
Daylight time (hr.): 8.52 |
Solar altitude (deg): 2.1959 |
Solar azimuth (deg): 127.0877 |
Linke turbidity factor: 3.1 |
Ground albedo: 0.200 |
r.sun -s elevin=“DEM” aspin=“DEM_asp” slopein=“DEM_sl” lin=3.1 alb=0\ |
.2 beam_rad=“1_8_b” diff_rad=“1_8_d” refl_rad=“1_8_r” day=1 step=0.5\ |
time=8 |
| Layer: 1_8_g Date: Fri Oct 12 08:20:06 2007 |
| Title: ( 1_8_g ) |
timestamp: none |
Data Type: FCELL |
Rows: 864 |
Columns: 1290 |
Range of data: min = -10.351157 max = 327.495667 |
Data Source: |
Data Description: |
generated by r.mapcalc |
Comments: |
1_8_b + 1_8_d + 1_8_r |
Thanks in advance for your help.
