[GRASS-user] What does agnps stand for in r.fill.dir
Hi
I can specify that the Output aspect direction format is in the agnps format. I understand the format, d=but I am wondering: what does agnps actually stand for?
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
On Fri, Sep 30, 2011 at 3:48 PM, ahmadou dicko <dicko.ahmadou@gmail.com> wrote:
Hi Rainer,
I think that AGNPS stand for AGricultural Non-Point Source Pollution Model, more info at : http://go.usa.gov/KFO
I found that as well - but the naming does not make that much sense, as agnps stands for a format of the flow direction? I assume, the coding of the direction is in line with what the AGNPS model needs.
Rainer
Ahmadou
2011/9/30 Rainer M Krug <r.m.krug@gmail.com>
Hi
Rainer
South Africa
Skype: RMkrug
grass-user mailing list
grass-user@lists.osgeo.org
South Africa
Skype: RMkrug
wrote:
Hi Rainer,
You can find (oldish) material about AGNPS here:
http://grass.osgeo.org/gdp/erosion/agnps/
wrote:
Hi Rainer,
Thanks - will look at it.
Rainer
South Africa
Skype: RMkrug
