I mis-configured the location of a postgres database. 'db.connect -p'
tells me it's in $GISDATABASE/$LOCATION/$MAPSET/ and it's not; it's in the
postgres data directory in /usr/local/pgsql/data/.
Where in each location or mapset directory is this information kept? I
want to modify the improper path and cannot find a db.* module to do this.
Rich
I mis-configured the location of a postgres database. ‘db.connect -p’
tells me it’s in $GISDATABASE/$LOCATION/$MAPSET/ and it’s not; it’s in the
Should be just db.connect driver=pg database=“dbname=…”
Micha Silver
GIS Consultant, Arava Development Co.
[http://www.surfaces.co.il](http://www.surfaces.co.il)
On Fri, 16 Mar 2012, Micha Silver wrote:
Should be just db.connect driver=pg database="dbname=..."
Micha,
I did re-run db.connect and that fixed the database location error. Is
this information stored in a file we can access?
Toda,
Rich
2012/3/16 Rich Shepard <rshepard@appl-ecosys.com>:
$GISBASE/$LOCATION_NAME/$MAPSET/VAR
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Martin,
Thanks!
Rich
