I'm trying to use grass6.3. When I launch it, I'm told it appears I haven't
set up my ssh keys. I answer the questions with the location it offers
(location of id_rsa), no passphrase. Then bash reports it can't access a
different directory looking for the file authorized_keys. When I type gis.m
at the prompt, the gui appears for a split second, and then disappears. The
terminal reports an error in the startup script. Can't read parts(w), no
such variable.
Any help appreciated.
Thanks, Jerry
View this message in context: http://www.nabble.com/why-does-grass-want-to-generate-an-ssh-key--tf2705286.html#a7543127
such variable.
GRASS itself doesn't use ssh, at least not directly. I can only assume
that something which is being called by the startup script is trying
to use it, but I have no idea what.
Try running the Init.sh script using "sh -x ...", e.g.:
GISBASE=/usr/local/grass-6.3.cvs
export GISBASE
sh -x $GISBASE/etc/Init.sh
This will print out each command it executes, which may provide some
clues as to exactly what is trying to use ssh.
