I have a source 28M DEM in a directory with geographic coordinates in
Lat/Long. When I re-project that to another location and dataset with
Lambert Conformal Conic projection the disk space consumed bloats to 106G.
That's more than a 20x increase. Why?
In the destination location/directory there's no .tmp/ subdirectory with a
huge file.
huge file.
Actually, there are two such files.
Am I correct in assuming that once the re-projection process is completed
I can delete those two files (called <pid>-1 and <pid>-2) without
consequences?
Related question: if they're no longer needed, why doesn't grass remove
them from the hard drive?
Some things come to mind:
1) The resolution has changed
2) the number of bits per pixel has changed
3) the region of the reprojected file is bigger than the original file
so you have lots of nulls.
Daniel
On Wed, Mar 14, 2012 at 12:28 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
huge file.
Which OS?
r.proj calls remove() on the temporary file immediately after opening
it. On Unix, that removes the directory entry, and will cause the file
itself to be deleted as soon as r.proj terminates. On Windows, the
remove() call will fail (you can't delete an open file on Windows),
and the file will be left behind.
r.proj calls remove() on the temporary file immediately after opening it.
On Unix, that removes the directory entry, and will cause the file itself
to be deleted as soon as r.proj terminates. On Windows, the remove() call
will fail (you can't delete an open file on Windows), and the file will be
left behind.
For some reason, then, it's not working here. Slackware-13.1/x486 and
-13.37/x86_64.
On the latter host I found two files in ../.tmp/<hostname>/: <pid>.1 and
<pid>.2. The former was almost 100G in size and the latter was >10G. The
source raster file is 45M in size.
On Thu, Mar 15, 2012 at 3:50 PM, Glynn Clements
Could|Will it be cleaned up when the Windows user leaves and reenters
the session? Or could a list of dead tmp files be generated to handle
this issue and savely remove them at next start up?
