[GRASS-user] Why does v.split convert 3D vector to 2D?
I have a 3D vector [test_3D] created using v.drape, confirmed as 3D with v.info. I used v.split to split the polyline at the vertices:
v.split input=test_3D output=test_3D_split vertices=2
The resulting vector [test_3D_split] is a 2D vector (i.e. it lost the z geometry data according to v.info, and v.to.db reports all slopes = 0).
Is this intended behavior?
Thanks, -Dwight
On Sun, Mar 7, 2010 at 7:13 PM, Dwight Needels <needels@translucida.com> wrote:
This happens due to the fact that the new vector file (output) is opened
without the Z geometry:
cd v.split/
grep open * | grep new
main.c: Vect_open_new(&Out, out_opt->answer, 0);
Certainly not ideal. I don't know if changing to
  Vect_open_new(&Out, out_opt->answer, WITH_Z);
would be sufficient (of course recompile after that). If you could
provide a test case with the Spearfish or North Carolina test
datasets, I could try if you aren't able to compile GRASS yourself
to test above suggestion.
cd v.split/
Markus, I would appreciate if you would be able to compile and test for me. Here is a Spearfish example that shows the same behavior (using v.info to test 2D/3D vector status).
v.drape input=t_hydro rast=elevation.dem output=t_hydro_3D method=cubic
v.split input=t_hydro_3D output=t_hydro_split vertices=2
Thanks, -Dwight
2010/3/7 Markus Neteler <neteler@osgeo.org>:
cd v.split/
should be fixed in r41335 (synchronized with trunk). Please test it. Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
On Sun, Mar 7, 2010 at 9:10 PM, Martin Landa <landa.martin@gmail.com> wrote:
cd v.split/
... for the list record, correction to my suggestion:
    Vect_open_new(&Out, out_opt->answer, Vect_is_3d(&In));
(obviously, open in 3D only when needed).
v.overlay is a similar candidate but maybe more complicated.
On Sun, Mar 7, 2010 at 8:50 PM, Dwight Needels <needels@translucida.com> wrote:
Looks good:
v.info t_hydro_split | grep 3D
| Map is 3D: Yes
##### orig map
v.to.db -p t_hydro option=slope
Reading features...
100%
cat|slope
-1|0
0 categories read from vector map (layer 1)
0 records updated/inserted (layer 1)
# draped map
v.to.db -p t_hydro_3D option=slope
Reading features...
100%
cat|slope
-1|-6.16016389653397
# split map
v.to.db -p t_hydro_split option=slope
Reading features...
100%
cat|slope
-1|-96.9755874160899
-> is that right? maybe there is some cat mess in the original map?
# 3D view:
v.info t_hydro_split | grep B
| B: 1085.64427482 T: 1698.36345331
-> reasonable
r.mapcalc "bottom = 1085"
nviz bottom vect=t_hydro_split
-> nice 3D vector lines
Looks good:
→ nice 3D vector lines
… now also for length option
Markus M
