The basin output from r.watershed frequently contains narrow, parallel
basins that are not realistic. This, of course, affects channel
determination, too. What might be the reason for this when the source DEM
does not display such inconsistencies?
Attached is such a map. The base DEM has a 10mx10m resolution (source:
National Elevation Dataset). The black lines are the HUC-12 sub-watershed
boundaries from the National Hydrographic Dataset. The red lines are the
vectorized bounds from r.watershed with a threshold of 125,000.
I'd like to understand why some of the r.watershed basins look like
squashed worms.
squashed worms.
By trial-and-error with different threshold values I think my original
value (125,000) was much too small. The threshold for this area should be
~400,000.
I’d like to understand why some of the r.watershed basins look like
squashed worms.
~400,000.
Try also multiple flow direction (MFD) algorithm ( -f flag in r.watershed)
madi,
That was much worse. The basins were even less realistic. I also tried the
-4 option, but that made rectangular basins. I thought the MFD would produce
better results than the SFD, but apparently not; at least, in this one
situation.
Rich
Richard B. Shepard, Ph.D. | Integrity - Credibility - Innovation
Applied Ecosystem Services, Inc. | Helping Ensure Our Clients' Futures
<http://www.appl-ecosys.com> Voice: 503-667-4517 Fax: 503-667-8863
On Sat, Jun 9, 2012 at 6:38 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
r.watershed)
madi,
situation.
These nearly straight red lines indicate that the DEM is flat in these
areas. What kind of pre-processing did you apply? Also, to reproduce
the results, the output of r.info of the DEM, g.region and g.proj
would be helpful.
Type of Map: raster Number of Categories: 255
Data Type: FCELL
Rows: 4694
Columns: 5457
Total Cells: 25615158
Projection: Transverse Mercator
N: 28704673.96487485 S: 28563905.79283388 Res: 29.98895868 |
E: 628305.08857358 W: 464582.93917488 Res: 30.00222639
Range of data: min = 1654.234 max = 3143.268
Data Description:
generated by r.patch
Comments:
r.patch input="dem2,dem3" output="dem_proj"
