it's some months now that I am trying to learn GRASS-GIS and I wonder
1. if one needs to copy some GRASS raster data from his data base in
another computer's GRASS data base (same coordinate system of course),
then how? Where do for example the history files go?
I understand (I think) the need to set-up properly a LOCATION and import
the data. But why isn't there a GRASS portable vector/ raster file
format?
2. the same about vector data
3. Is it really necessaty to export in shapefiles when working with
starspan? If there is "GRASS read-only" support by OGR why is it
necessary to export?
What about OpenEV? If GDAL is built with GRASS support why can't it read
GRASS rasters?
1.. if one needs to copy some GRASS raster data from his data base in
See r.pack/r.unpack in the Grass Add-ons. I use these scripts for moving
rasters around from computer to computer:
The r.pack script uses a MatLab format file as an intermediary, and is apparently
a decent universal format for storing rasters in.
format?
I think r.in/out.ascii and v.in/out.ascii are designed for this? Not 100%
sure, but check the man pages for these two commands.
See above.
I can't comment on Starspan; never used it.
GRASS rasters?
O.K.
>format?
I am checking... It's just that I had the impression that exporting in
ascii is always a bit "dangerous" concerning the metadata this is why I
try to avoid it.
See above.
>GRASS rasters?
> in another computer's GRASS data base (same coordinate system of
> course), then how? Where do for example the history files go?
is apparently a decent universal format for storing rasters in.
In hindsight exporting to another format will always be problematic and
potentially lossy, it would be better to rewrite r.pack by simply
finding the GRASS files and zipping them up, then have r.unpack
distribute them back around.
> import the data. But why isn't there a GRASS portable vector/
> raster file format?
the easiest way to move grass data is to tarball/zip up the location
directory and copy it across. If you want just one or two select raster
maps use g.copy from a temporary mapset, then zip up the location with
just the temporary and PERMANENT mapsets.
it is hoped for GRASS 7 to move raster maps into a per-map directory
structure like the vector maps instead of having them spread their
parts all over the mapset.
vector data is easy, just copy over the data's folder in the
$MAPSET/vector/ directory, and it's database file too. Make sure to
reconnect the database once it arrives at its new home.
