[GRASS-user] wiki page for compiling on Ubuntu
Dear all,
I started a wiki page on compiling on Ubuntu including the changes I needed on recent versions:
http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu
Please feel free to add your observations.
Kind regards,
Timmie
On 13/06/09 14:17, Tim Michelsen wrote:
Dear all,
I think it would be better to work here:
http://grass.osgeo.org/wiki/Compile_and_Install#Ubuntu
Moritz
Yes.
But as my instructions differ from what people used on the LTS version, I though
to start a new page.
I have nothing against combining things.
Let's use the new page to develop a guide for
* current LTS
* current release
and then merge it back to the main page.
any suggestions & edits welcome.
BTW, where do I report errors with the UbuntuGIS PPA packages?
Best regards,
Timmie
I guess here
http://lists.osgeo.org/mailman/listinfo/ubuntu
-- Giovanni --
I guess here
I put it here:
https://bugs.launchpad.net/ubuntu/+source/geos/+bug/387299
What to do under the current situation if libgeos does not work:
1) open synaptic
2) search for geos
3) select the package libgeos-c1
4) menu package -> force version -> select the "jaunty" version (not PPA)
5) apply changes
6) select the package libgeos-c1
7) secure version
Here are more infos:
http://lists.osgeo.org/pipermail/ubuntu/2009-May/000016.html
Yes.
* current LTS
* current release
I don't really see the need for that. A Wiki is a live document, no need to work on a draft somewhere else, but oh well...
Generally, on any Debian-derived distro I would always recommend using the 'fakeroot dpkg-buildpackage' route, instead of e.g. checkinstall. The Debian-GIS project provides debian/ folders for most GRASS versions. Using those ensures that you packages fits better into the normal Debian(/Ubuntu) structure and also why not use these great tools when they are available.
Here's the general procedure I generally recommend:
- apt-get install fakeroot
- apt-get build-dep grass #to install all necessary dependencies
- mkdir grass_builddir #create the build directory
- cd grass_builddir
- download and unpack desired GRASS source code
- follow instructions in debian/README, using either svn://svn.debian.org/pkg-grass/packages/grass/trunk/debian or a relevant tag, such as svn://svn.debian.org/pkg-grass/packages/grass/tags/6.4.0~rc5-1/debian
- in the GRASS source directory: 'fakeroot dpkg-buildpackage'
- if the compilation works well: move up one directory (cd ..)
- sudo dpkg -i *.deb #to install all deb packages just created
Feel free to add this to the wiki, if you think this relevant.
Moritz
