Hi list. I don't understand the following:
while the command
# outside of grass' shell
"ls -l MOD09GA_???_!(203)_*_sur_refl_b01"
works fine under (normal) bash (version 3.2.48(1)) [1], the same search
pattern fails to give results when used with g.mlist and returns an
error. E.g.,
# from within grass' shell
"g.mlist pat=MOD09GA_???_!(203)_500m_sur_refl_b0?"
bash: !: event not found
The same error is returned even when I use "-r", "-e" switches with
g.mlist, as well as when I define the string within double quotes [2].
The command does not return anything if the string is placed in single
ticks (')[3].
However, escaping the parentheses works under grass but not under bash.
e.g.:
g.mlist pat=MOD09GA_2007_\(203\)*_sur_refl_b01
MOD09GA_2007_203_500m_sur_refl_b01
ls MOD09GA_2007_\(203\)*_sur_refl_b01
ls: cannot access MOD09GA_2007_(203)*_sur_refl_b01: No such file or
directory
In addition, the string "MOD09GA_???_{203}_*_sur_refl_b01" (using curly
braces) works under grass but _not_ under bash.
There is the "exclude" parameter for g.mlist which finally does what I
want to do. Yet, I would like to know what is the explanation for this
behaviour?
I've been through the manuals [M1][M2] but I have no idea where to trace
this down. Is it that I don't understand the regular/ extended
expressions [4] or is it something special/different to grass?
Kind regards, Nikos
[1] ls MOD09GA_???_!(203)_*_sur_refl_b01
MOD09GA_2007_202_500m_sur_refl_b01 MOD09GA_2007_208_500m_sur_refl_b01
MOD09GA_2008_205_500m_sur_refl_b01 ...
[2] both of the following return the same error
g.mlist pat="MOD09GA_???_!(203)_*_sur_refl_b01" -r
g.mlist pat="MOD09GA_???_!(203)_*_sur_refl_b01" -e
[3] using simple ticks: no error message but no result either
g.mlist pat='MOD09GA_???_!(203)_*_sur_refl_b01' -e
g.mlist pat='MOD09GA_???_!(203)_*_sur_refl_b01' -r
[4] http://en.wikipedia.org/wiki/Regular_expression
[M1]
http://grass.osgeo.org/grass64/manuals/html64_user/variables.html#enviro
[M2] http://grass.osgeo.org/grass64/manuals/html64_user/g.mlist.html
