I installed the Windows version of Grass 6.4.0SVN using the
stand-alone installer package by Colin Nielsen onto a Windows Vista
32-bit machine. The installation seemed perfect. When I try to run
the program I get a window containing the following error:
python.exe - Entry Point Not Found
The procedure entry point
?PyWinObject_AsHANDLE@@YAHPAU_object@@PAPAX@Z could not
be located in the dynamic link library pywintypes25.dll.
When the error window is closed, another identical window appears.
When it is closed Grass shuts down. Can anyone help me get it
running?
Matt
