hi,
Glynn Clements glynn at gclements.plus.com
You need to add the directory where the DLLs reside to the PATH
setting. Or copy the DLLs to the dist.<arch>/lib directory (or to
Windows' System32 directory).
i will try the above later
i've added the directories of postgres and sqlite to the PATH and everything compiled
fine and tcltk- and wxpython-gui works also fine.
great work for the new gui!
so i'am able to test the new gui a little bit. where should i put some comments etc.?
maybe on the wiki, trac, mailinglist ...?
best regards
helli
_______________________________________________________________________
Jetzt neu! Schützen Sie Ihren PC mit McAfee und WEB.DE. 30 Tage
kostenlos testen. http://www.pc-sicherheit.web.de/startseite/?mc=022220
