[GRASS-user] WinGrass-6.4.0-1-Setup.exe crash
I downloaded and installed WinGrass-6.4.0-1-Setup.exe. When I try to run
"GRASS 6.4.0 with MSYS" from the desktop, the terminal session starts up
fine and several windows open. When I highlight a dataset in the GRASS GIS
gui and hit "Start GRASS", I get a popup window "execution failed 'g.proj
-p'" and this error stack when I hit "OK" for the popup window. Can you
help me fix this problem? Thank you.
Dan Connors
GRASS 6.4> Traceback (most recent call last):
  File "c:/Program Files/GRASS-64/etc/wxpython/wxgui.py", line 1834, in
<module>
    sys.exit(main())
  File "c:/Program Files/GRASS-64/etc/wxpython/wxgui.py", line 1827, in main
    app = GMApp(workspaceFile)
  File "c:/Program Files/GRASS-64/etc/wxpython/wxgui.py", line 1752, in
__init__
    wx.App.__init__(self, False)
  File "C:\Program
Files\GRASS-64\Python25\lib\site-packages\wx-2.8-msw-unicode\wx\_core.py",
line 7935, in __init__
    self._BootstrapApp()
  File "C:\Program
line 7509, in _BootstrapApp
    return _core_.PyApp__BootstrapApp(*args, **kwargs)
  File "c:/Program Files/GRASS-64/etc/wxpython/wxgui.py", line 1770, in
OnInit
    workspace = self.workspaceFile)
  File "c:/Program Files/GRASS-64/etc/wxpython/wxgui.py", line 192, in
__init__
    self.NewDisplay(show=False)
  File "c:/Program Files/GRASS-64/etc/wxpython/wxgui.py", line 1248, in
NewDisplay
    auimgr=self._auimgr, showMapDisplay=show)
  File "c:\Program Files\GRASS-64\etc\wxpython\gui_modules\wxgui_utils.py",
line 95, in __init__
    self.Map = render.Map() # instance of render.Map to be associated
with display
  File "c:\Program Files\GRASS-64\etc\wxpython\gui_modules\render.py", line
402, in __init__
    self.projinfo = self.ProjInfo()
765, in ProjInfo
    p = gcmd.Command(['g.proj', '-p'])
  File "c:\Program Files\GRASS-64\etc\wxpython\gui_modules\gcmd.py", line
369, in __init__
    _("Error: ") + self.GetError()))
gui_modules.gcmd.CmdError
GRASS 6.4>
View this message in context: http://osgeo-org.1803224.n2.nabble.com/WinGrass-6-4-0-1-Setup-exe-crash-tp5762566p5762566.html
Can you please try with the more recent
http://grass.osgeo.org/grass64/binary/mswindows/native/WinGRASS-6.4.SVN-r44203-1-Setup.exe
GIS
grass-user mailing list
grass-user@lists.osgeo.org
Markus,
I installed WinGRASS-6.4.SVN-r44203-1-Setup.exe. When I launch Start GRASS,
I now get this error:
Unable to get current geographic extent. Force quiting wxGUI. Please run
manually g.region to fix the problem. Reason:No module called
customtreectrl
Dan
View this message in context: http://osgeo-org.1803224.n2.nabble.com/WinGrass-6-4-0-1-Setup-exe-crash-tp5762566p5765312.html
