Hi
I'm using WinGRASS (6.4.1) in Osgeo4w and I'm having a problem in the import of GRIB files. I'm using r.in.gdal, as I have used in Linux, and I'm obtaining the following error:
ERROR 4: `C:\Data\GISDataBase\GRIB_codes\new03.grib' not
recognised as a supported file format.
What might be missing?
Thanks
Antonio
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5657 (20101129) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
Olá António
On my windows VM, I have an older osgeo4w install, that hasn't got
GRIB support available. Maybe thats your problem as well? Run the
command
gdalinfo --formats
through the osgeo4w shell. Look for the GRIB format at the output.
If you cannot find a line that says GRIB there, your GDAL doesn't
support it, and GRASS won't be able to read it, as it depends on GDAL.
2010/11/29 António Rocha <antonio.rocha@deimos.com.pt>:
Hi
Thanks
Antonio
http://www.eset.com
grass-user mailing list
grass-user@lists.osgeo.org
___________________________ ___ __
Ricardo Garcia Silva
Hello
Thanks Ricardo. That is the problem. My GDAL, installed withg OSGEO4w is not able to open/process GRIB files.
Has anyone changed GDAL version in OSGEO4w in Windows?
Thanks
Antonio
Quoting "Ricardo Filipe Soares Garcia da" <ricardo.garcia.silva@gmail.com>:
Olá António
command
gdalinfo --formats
Hi
Thanks
Antonio
http://www.eset.com
