I would like to know if there are news about installing extensions from the repository. I´m ussing Grass 7.6.1 in Windows.
However, I´ve download zip file (r.landscape.evol) and I tried to install it manually:
g.extension extension=r.landscape.evol url=C:\OSGeo4W64\apps\grass\r.landscape.evol.zip
Downloading precompiled GRASS Addons <r.landscape.evol>…
ERROR: Extension <r.landscape.evol> not found
I tried different paths, / instead , but i can´t get it…
Thank you!
hellik
2
the
it manually:
<r.landscape.evol>
ERROR: Extension
<r.landscape.evol>
not found
I tried different paths, / instead \, but i can´t get it...
still work in progress.
as a workaround:
° download zipped r.landscape.evol from here [1]:
https://wingrass.fsv.cvut.cz/grass76/x86_64/addons/latest/r.landscape.evol.zip
° unzip
° copy the content of the subfolders into the equivalent subfolders under
C:\Users\YourUserName\AppData\Roaming\GRASS7\addons
° start a winGRASS session and start the addon in the command line
HTH
[1] https://wingrass.fsv.cvut.cz/grass76/x86_64/addons/latest/
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
I could do it! Thank you very much for your help
El lun., 22 de jul. de 2019 a la(s) 11:04, Helmut Kudrnovsky (hellik@web.de) escribió:
the
it manually:
<r.landscape.evol>
ERROR: Extension
<r.landscape.evol>
not found
as a workaround:
° unzip
HTH
best regards
Helmut
grass-user mailing list
grass-user@lists.osgeo.org
Hello again, when I run r.landscape.evol, now I get this error:
File “C:\Users\USUARIO\AppData\Roaming\GRASS7\addons/scrip
ts/r.landscape.evol.py”, line 665, in
f = file(statsout, ‘wt’)
IOError: [Errno 13] Permission denied:
u’PERMANENT_levol_lsevol_stats.csv’
it´s appears as if the path to the rules file must be error or missing?
My user is administrator.
Thanks for your help!
El lun., 22 de jul. de 2019 a la(s) 11:23, Maria Cecilia Zalazar (zalazarmariacecilia@gmail.com) escribió:
the
it manually:
<r.landscape.evol>
ERROR: Extension
<r.landscape.evol>
not found
as a workaround:
° unzip
HTH
best regards
Helmut
I was able to fixed it. Thanks very much at all!
El lun., 22 de jul. de 2019 a la(s) 16:20, Maria Cecilia Zalazar (zalazarmariacecilia@gmail.com) escribió:
the
it manually:
<r.landscape.evol>
ERROR: Extension
<r.landscape.evol>
not found
as a workaround:
° unzip
HTH
best regards
Helmut
