I’m running winGrass 6.4.1 on winXP and trying to use the wingrass ODBC driver to connect to an Oracle database.
I’ve used db.login and db.connect to define the database and user. When I run db.tables -p a windows pops up with an error message:
Error odbc.exe has encounted a problem and needs to close
Do any winGrass versions - 6.4.1 or 6.5 or 7 - work with the Grass ODBC driver and Oracle?
Also, are any of the Windows precompiled binaries available with the ODBC driver?
Any help on this would be appreciated because I’d like to move my attribute tables from the dbf driver.
On Fri, Apr 29, 2011 at 8:37 AM, Sharon M <morrisxs09@gmail.com> wrote:
I'm running winGrass 6.4.1 on winXP and trying to use the wingrass ODBC
I've used db.login and db.connect to define the database and user. When I
That will likely be the odbc driver.
driver and Oracle?
driver?
No experience ... maybe it is worth to ask on the OSGeo4W list?
Any help on this would be appreciated because I'd like to move my attribute
driver and Oracle?
driver?
No experience … maybe it is worth to ask on the OSGeo4W list?
