Hi again,
sorry for posting again, but somehow I can't get it work to
run GRASS GIS using my local Python 2.7 installation.
See comments below:
-------- Original-Nachricht --------
Datum: Mon, 5 Sep 2011 01:57:38 +0100
Von: Glynn Clements <glynn@gclements.plus.com>
An: "Johannes Radinger" <JRadinger@gmx.at>
CC: grass-user@lists.osgeo.org, grass-windows@lists.osgeo.org
Betreff: Re: [GRASS-user] Re: [GRASS-windows] WinGRASS Python 2.7
Johannes Radinger wrote:
> As recommended I did the changes.
> I just tried to first disable the PYTHONHOME and
> GRASS_PYTHON. The lines in the env.bat file are now:
> rem Path to the python directory
> rem set PYTHONHOME=%GISBASE%\Python25
> rem if "x%GRASS_PYTHON%" == "x" set GRASS_PYTHON=python
> is that correct?
> I tried at this step to start GRASS but it doesn't work
> anymore. Nothing is started!! So it seems that this isn't
> working! Maybe I have to set the path to python.org in the
> env.bat, but I don't know how the lines should look like.
For the GUI, setting e.g.:
set GRASS_PYTHON=c:\Program Files (x86)\Python27\pythonw.exe
should suffice.
So what I tried now were three different settings in the env.bat
1)
set GRASS_PYTHON=C:\Program Files (x86)\Python27\pythonw.exe
in this case: GRASS is starting using the Python25
2)
in this case: Nothing is started!
3)
set C:\Program Files (x86)\Python27
Just to inform you why I need that: I wrote a .py script (including g.parser elements) which I want to call inside GRASS with "file.py" (like any other modules e.g. r.fuzzy etc.) The script is working (tested on my Mac using GRASS in combination with Python 2.7)! The script calls scipy which can only be used in combination with Python 2.6 or newer (so far as I remember).
So hopefully this issue can be solved as soon as possible as I want to use the script also on my windows-office computer!!
Thank you
Johannes
If you want to run Python scripts from bash, you may run into problems
if there are any spaces in any of the directories. Using an 8.3
filename may work, e.g.:
export PATH=$PATH:/c/PROGRA~2/Python27/pythonw.exe
Running Python scripts from cmd.exe should use the file association
for the .py extension.
grass-user mailing list
NEU: FreePhone - 0ct/min Handyspartarif mit Geld-zurück-Garantie!
Jetzt informieren: http://www.gmx.net/de/go/freephone
