When I start WinGRASS 6.3 in Command line mode I'm not able to open a
monitor. I tried with
d.mon start=x0, but it doesn't work. Any suggestion?
Thanx, Gianandrea
View this message in context: http://www.nabble.com/WinGrass-start-monitor-tp20032047p20032047.html
I noticed the same problem some weeks ago.
Now I created a ticket.
http://trac.osgeo.org/grass/ticket/339#preview
Maybe you can add your own experience
best regards
Alex
Thanx, Gianandrea
Monitors don't work on Windows. If you run a d.* command, it will just
create an image (by default, a PNG file named map.png). d.* commands
which use the mouse just won't work; you'll need to see if there's
equivalent functionality in the GUI.
