[GRASS-user] . winGRASS tester needed ... to fix upcoming releases
With PYTHONUTF8=1 set in the bat, I imported some rasters and created a map
in GRASS 7.8.5, all fine.
The only thing I found so far was when trying to close Grass I got an
windows OS error message that read 'Python stopped working' . I could not
find an error.log for this so far
Karsten
-----Original Message-----
Sent: Friday, May 07, 2021 11:33
To: 'grass-user@lists.osgeo.org'
Subject: RE: . winGRASS tester needed ... to fix upcoming releases
On my windows 10 machine and using Grass version 7.8.5 I have added set
PYTHONUTF8=1 to the bat file and Grass is starting up fine. I will report
any issues that I'll find
Karsten
From: grass-user [mailto:grass-user-bounces@lists.osgeo.org] On Behalf Of
grass-user-request@lists.osgeo.org
Sent: Thursday, May 06, 2021 14:12
To: grass-user@lists.osgeo.org
Subject: grass-user Digest, Vol 181, Issue 3
Send grass-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
  grass-user-owner@lists.osgeo.org
When replying, please edit your Subject line so it is more specific than
"Re: Contents of grass-user digest..."
Today's Topics:
   1. winGRASS tester needed ... to fix upcoming releases :slight_smile: ....
      nobody out there willing to test? (Helmut Kudrnovsky)
   2. Re: winGRASS tester needed ... to fix upcoming releases :slight_smile:
      .... nobody out there willing to test? (Maria Cecilia Zalazar)
   3. Re: winGRASS tester needed ... to fix upcoming releases :slight_smile:
Message: 1
Date: Thu, 6 May 2021 22:20:23 +0200
Subject: [GRASS-user] winGRASS tester needed ... to fix upcoming
  releases :slight_smile: .... nobody out there willing to test?
Message-ID:
<trinity-050dd24e-81ac-4865-a0a1-ebf5a0c3161b-1620332423809@3c-app-webde-bap
16>
Content-Type: text/plain; charset=UTF-8
mail below was sent on Wed Apr 14 2021 => no reaction, no one a minute to
test?
if no one of the community has a minute to test winGRASS, then I guess it's
time to propose to the PSC dropping winGRASS at all....
kind regards
Helmut
dear GRASS GIS community,
testing of winGRASS is a important piece of puzzle to guarantee a stable and
useable software on the MS windows platform in the future.
For this, we would need the help of the community now. :slight_smile:
background is an _error in g.extension while installing i.fusion.hpf in
windows_
some more information
https://github.com/OSGeo/grass/issues/1477
https://github.com/OSGeo/grass/pull/1496
it's an encoding issue while opening files via python.
a possible solution may be set PYTHONUTF8=1 as environment variable.
and a way how you could help, just add
set PYTHONUTF8=1
in C:\OSGeo4W64\apps\grass\grass79\etc\env.bat just before GRASS_PYTHON is
set. (or in the same file in the standalone winGRASS installation).
it would look like:
set PYTHONUTF8=1
set GRASS_PYTHON=%OSGEO4W_ROOT%\bin\python3.exe
and then happy GRASS GIS working :slight_smile: and report back if there are any issues
in your daily winGRASS work.
kind regards
Helmut
Message: 2
Date: Thu, 6 May 2021 17:47:19 -0300
From: Maria Cecilia Zalazar <zalazarmariacecilia@gmail.com>
To: Helmut Kudrnovsky <hellik@web.de>
Cc: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] winGRASS tester needed ... to fix upcoming
Message-ID:
  <CADLxGovin56s+qdzPDbtRqLXrQqwnq55CSfPcY9RaNfD2SOOmw@mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
Dear Grass community, I?m using wingrass 7.8.5 (daily, mainly to process and
analyze raster DEM). No new issues to report in my daily task. But if I try
to install i.fusion.hpf, as Helmut suggested, I obtain the following error
message. I hope it is useful. Best regards
Downloading precompiled GRASS Addons <i.fusion.hpf>...
Fetching <i.fusion.hpf> from <
http://wingrass.fsv.cvut.cz/grass78/x86_64/addons/grass-7.8.5/i.fusion.hpf.z
ip>
(be patient)...
  File
"C:\OSGeo4W64\apps\grass\grass78/scripts/g.extension.py",
line 2350, in <module>
    sys.exit(main())
  File
line 2330, in main
    install_extension(source=source, url=url, xmlurl=xmlurl,
branch=branch)
  File
line 871, in install_extension
    ret1, new_modules_ext, new_files_ext =
install_extension_win(extension)
  File
line 1259, in install_extension_win
    for line in file:
  File "C:\OSGeo4W64\apps\Python37\lib\fileinput.py", line 252, in __next__
    line = self._readline()
  File "C:\OSGeo4W64\apps\Python37\lib\fileinput.py", line 366, in _readline
    return self._readline()
  File "C:\OSGeo4W64\apps\Python37\lib\encodings\cp1252.py",
line 23, in decode
    return
codecs.charmap_decode(input,self.errors,decoding_table)[0]
UnicodeDecodeError: 'charmap' codec can't decode byte 0x9d in position 401:
character maps to <undefined>
El jue, 6 de may. de 2021 a la(s) 17:27, Helmut Kudrnovsky (hellik@web.de)
escribi?:
to test?
it's time to propose to the PSC dropping winGRASS at all....
kind regards
Helmut
stable and useable software on the MS windows platform in the future.
in windows_
set PYTHONUTF8=1
GRASS_PYTHON is set. (or in the same file in the standalone winGRASS
installation).
it would look like:
set PYTHONUTF8=1
issues in your daily winGRASS work.
kind regards
Helmut
URL:
<http://lists.osgeo.org/pipermail/grass-user/attachments/20210506/333c9f5e/a
ttachment-0001.html>
Message: 3
Date: Thu, 6 May 2021 18:11:53 -0300
Message-ID:
  <CADLxGot2c4-42Zs3uEHKPNa20FH=H85=C6yg51Qfa4vUsGg5gw@mail.gmail.com>
Sorry.... and If I added "set PYTHONUTF8=1" in
C:\OSGeo4W64\apps\grass\grass78\etc\env.bat just before GRASS_PYTHON is
setting, grass stops to work...
[image: image.png]
El jue, 6 de may. de 2021 a la(s) 17:47, Maria Cecilia Zalazar (
zalazarmariacecilia@gmail.com) escribi?:
process and analyze raster DEM). No new issues to report in my daily
task. But if I try to install i.fusion.hpf, as Helmut suggested, I
obtain the following error message. I hope it is useful. Best regards
.hpf.zip>
(be patient)...
  File
    sys.exit(main())
  File
line 2330, in main
branch=branch)
  File
  File
    for line in file:
__next__
_readline
line 23, in decode
    return
401: character maps to <undefined>
(hellik@web.de)
escribi?:
minute to test?
guess it's time to propose to the PSC dropping winGRASS at all....
kind regards
Helmut
in windows_
set PYTHONUTF8=1
installation).
it would look like:
set PYTHONUTF8=1
kind regards
Helmut
URL:
<http://lists.osgeo.org/pipermail/grass-user/attachments/20210506/d78826f3/a
ttachment.html>
Type: image/png
Desc: not available
URL:
ttachment.png>
Subject: Digest Footer
End of grass-user Digest, Vol 181, Issue 3
