Hi,all
I find wingrass6svn could not use “d.mon start=PNG” and wingrass7svn can not start in gui normally. the python.exe error of wingrass7 gui starting is ""sqlite3-rtree-geometry-callback" not found in the dll "sqlite3.dll".
thanks!
Dehui Wang
Hi,all
thanks!
Dehui Wang
On Wed, Oct 24, 2012 at 7:39 AM, 王德辉 <dehuiw@gig.ac.cn> wrote:
Hi,all
I find wingrass6svn could not use "d.mon start=PNG" and wingrass7svn can not
There is an open ticket for this:
https://trac.osgeo.org/osgeo4w/ticket/305
It would be very good if you could add a note in this ticket
that it also affects you - to raise the importance. It is an
OSGeo4W packaging issue and cannot be directly influences
by the GRASS developers.
best,
Hi,all
""sqlite3-rtree-geometry-callback" not found in the dll "sqlite3.dll".There is an open ticket for this:
https://trac.osgeo.org/osgeo4w/ticket/305It would be very good if you could add a note in this ticket
It seems that WinGRASS (WinGRASS-7.0.svn-r53520-384-Setup.exe) is affected too.
Message after starting GUI is:
Can not find entry point sqlite3_rtree_geometry_callback of the
procedure in the dynamic link library sqlite3.dll.
Is there any solution or workaround for user, like to use older
version of WinGRASS or sqlite/spatialite?
Vaclav
too.
yes, because based on the osgeo4w-build-environment.
AFAIK a repackaging in osgeo4w is needed. no idea which older
sqlite/spatialite-versions could work.
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/wingrass6-d-mon-png-and-wingrass7-gui-start-failure-in-XP-tp5010686p5010831.html
Hi Vaclav, I had the same problem; as a workaround I searched in Google a new (recent) version of sqlite3.dll and I copy it in apps/python27/DLLS, replacing the old one;
Now everything if working: anyway, I hope that OSgeo4W will soon replace directly in the compiled package.
ciao,
roberto
