[GRASS-user] wingrass7 start and location
Dear all,
I have just installed Wingrass7 from
[http://josef.fsv.cvut.cz/wingrass/grass70/\]
When it is started the locations which work well with Grass6.4 version,
there is the error: Unable to get current geographic extent. Force
quitting wxGUI. Please run manual g.region to fix
problem....Importerror: No module named agw.customtreectrl
Or when I make new location by Location wizard there is the error: ..
[Error 2] No such file or directory: 'C:\\Program Files\\
GRASS-70-SVN\\etc\\proj-parms.table'
Please help me what should I do?
Thank you
Thy
I can confirm this.
at the moment the nightly WinGrass7-builds are built against gdal17 from osgeo4w,
which is in a preliminary status at the moment.
I build from time to time WinGrass7 for my own with gdal16 from osgeo4w and there are
no such error messages.
best regards
Helmut
it seems to be a mixing of different gdal-versions.
WinGrass70 is built against gdal17. but in WinGrass7 (installed by the installer) there is
only gdal15 in the path and available in the WinGrass7-command-line, but no gdal17.
AFAIK there are some important changes from gdal15 to gdal17. so a WinGrass7 built against gdal17
isn't working with gdal15 in the path?
so maybe the WinGrass7-installer built against gdal17 should be adapted in that way to adopt gdal17 as the regular version
of gdal?
best regards
Helmut
___________________________________________________________
GRATIS: Spider-Man 1-3 sowie 300 weitere Videos!
Jetzt kostenlose Movie-FLAT freischalten! http://movieflat.web.de
