Dear all,
I am trying to transform a polygon layer to lines with a command like:
v.to.lines input=country_borders output=country_borders_lines --overwrite
This command fails because GRASS tries to create a temporary table whose column names are SQL keywords:
DBMI-PostgreSQL driver error:
Unable to execute:
CREATE TABLE country_borders_tmp_1513280_2 (cat integer,left integer,right integer)
ERROR: syntax error at or near “left”
LINE 1: … TABLE country_borders_tmp_1513280_2 (cat integer,left integ…
For Postgres the correct command would have to be:
CREATE TABLE country_borders_tmp_1513280_2 (cat integer,“left” integer,“right” integer);
But could be different for other DBMS. In general it is not a good idea to use SQL keywords to name objects in a relational database.
To the question: is there a workaround for this problem? Can GRASS be instructed to not use SQL keywords as column names? Or somehow create valid SQL queries, for instance using double quotes?
Thank you.
Luís
Sent with ProtonMail Secure Email.
