[GRASS-user] working on a mounted external disk
Hello,
has anybody ever had problems accessing a gisdbase located on an
external disk ? In my case, I can open a grass session in a distant
location/mapset :
        grass65 /mnt/path_to_my_disk/my_location/topo
From within this place, everything works well, OK.
If I start grass from my home directory and try to reproject data from
the distant directory :
        grass65 /home/vincent/my_gisdbase/my_location/my_mapset
        r.proj input=dem50 location=/mnt/path_to_my_disk/my_location
        mapset=topo output=dem50
Then an error occurs :
        ERREUR :Mapset <topo> in input location
        </mnt/path_to_my_disk/my_location/> - not found
whereas the disk is properly mounted there and accessible...
Any idea on why grass seems not to see the mounted directory ?
Thank you
Vincent
On 08/04/09 10:31, Vincent Bain wrote:
Hello,
location/mapset :
You need to use the dbase= option of r.proj to direct it to another database. In your case it is looking for a location called "/mnt/path_to_my_disk/my_location/" in your current gisdatabase.
Moritz
Thank you Moritz,
I tried to specify the path to the target database location this way :
        mapset=topo dbase=/mnt/path_to_my_disk/ output=dem50
unfortunately it still returns the same error.
Well, maybe I should change the title of this post, because I notice now
that the problem is the same with "resident" paths on the machine
(apparently nothing to deal with mounted directory).
Vincent
Moritz
On 08/04/09 11:51, Vincent Bain wrote:
Thank you Moritz,
this should be:
r.proj input=dem50 location=my_location
If you give it location=/mnt/path_to_my_disk/my_location
it "thinks" that the location is called "/mnt/path_to_my_disk/my_location" as the error message indicates:
Moritz
Vincent
Moritz
OH, that simple ! shame on me :frowning:
Sorry for being so dazed...
A detail concerning r.proj in that context of distinct gisdbases :
if the distant location has the same name as the current (i.e. in my
example both locations are called 'my_location'), then the command
returns a comprehensible error :
ERROR: You have to use a different location for input than the current
It would be nice if the dbase argument was checked /before/ the location
argument, in order to admit same location names, not necessarily meaning
that we project data in an identical projection system.
Vincent
Le mercredi 08 avril 2009 à 13:41 +0200, Moritz Lennert a écrit :
this should be:
Moritz
Try this (untested):
Index: raster/r.proj/main.c
--- raster/r.proj/main.c (révision 36609)
+++ raster/r.proj/main.c (copie de travail)
@@ -219,7 +219,7 @@
      setname = imapset->answer ? imapset->answer : G_store(G_mapset());
- if (strcmp(inlocation->answer, G_location()) == 0)
+ if (strcmp(inlocation->answer, G_location()) == 0 && (!indbase->answer || strcmp(indbase->answer, G_gisdbase()) == 0))
    G_fatal_error(_("You have to use a different location for input than the current"));
      G_get_window(&outcellhd);
Moritz
           !indbase->answer || strcmp(indbase->answer, G_gisdbase())==
        0))
          G_fatal_error(_("Input and output locations can not be the
        same"));
Then compiled and installed again, but the error remains, and what's
more puzzling to me is that the message string is different from what I
have in the modified file ("You have to use a different location for
input than the current")...
What have I done wrong ?
VB
@@ -219,7 +219,7 @@
the current"));
Moritz
        0))
        same"));
This sounds like you modified and compiled a grass6 version, but are running grass7.
Apparently a fix for this issue done by Markus a long time ago in grass6, but this got lost, when (IIUC) r.proj.seg became r.proj in grass7.
Markus' fix was this:
-if (strcmp(inlocation->answer, G_location()) == 0)
- G_fatal_error(_("You have to use a different location for input
- than the current"));
+ if (!indbase->answer && strcmp(inlocation->answer, G_location()) == 0) + G_fatal_error(_("Input and output locations can not be the same"));
but this was never applied to r.proj.seg. His fix does not take into account the case where someone gives a value for dbase, but this is the same as the current location. Probably highly improbable, but not impossible, so my fix is a bit more complete...
So, to make this story short:
- You have to figure out which version of grass you are working with.
- In grass6.3+ this shouldn't be an issue, but it is in grass6.2 and before and again in grass7.
- The message ""You have to use a different location for input than the current" is in grass6.2 and before and in grass7, but was changed to "Input and output locations can not be the same" in grass6.3+.
I'll apply my fix (but using Markus' wording) grass7, but I'll leave devel6 alone as the Markus' fix should handle most cases.
Moritz
OK, I've got it : I made changes to raster/r.proj/main.c instead of
raster/r.proj.seg/main.c
Now it works fine with the right main.c file !
Thank you,
Vincent
