Dear there,
I’m currently using GRASS 7 python shell on Windows 7 processing thousands of raster images.
It’s inconvenient to test the code either by copying the code line by line or by running it using ‘Launch script’ from GUI.
Following the code in this link http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly#Python:_GRASS_GIS_7_with_existing_location, I want to work with GRASS under Python environment.
I reset three parts to my computer’s setting:
grass7bin_win = r’C:/Program Files (x86)/GRASS GIS 7.0.0/grass70.bat’
location = “MODIS_GUIWAGOU”
mapset = “GUIWAGOU”
But I got this error:
File “F:\PYTHON\PYTHON_GRASS7.py”, line 81, in
for rast in grass.list_strings(type = ‘rast’):
File “C:\Program Files (x86)\GRASS GIS 7.0.0\etc\python\grass\script\core.py”, line 1110, in list_strings
mapset=mapset).splitlines():
File “C:\Program Files (x86)\GRASS GIS 7.0.0\etc\python\grass\script\core.py”, line 427, in read_command
return handle_errors(returncode, stdout, args, kwargs)
File “C:\Program Files (x86)\GRASS GIS 7.0.0\etc\python\grass\script\core.py”, line 310, in handle_errors
returncode=returncode)
CalledModuleError: Module run None [‘g.list’, ‘–q’, ‘-m’, ‘type=rast’] ended with error
Process ended with non-zero return code -1073741511. See errors in the (error) output.
Do you know what’s wrong?
Thank you for your help in advance!
Best,
Xiaoye
On Tue, Mar 24, 2015 at 11:48 AM, TongXiaoye <tongcaptaintong@hotmail.com>
wrote:
Dear there,
I'm currently using GRASS 7 python shell on Windows 7 processing
It's inconvenient to test the code either by copying the code line by line
or by running it using 'Launch script' from GUI.
I reset three parts to my computer's setting:
*grass7bin_win = r'C:/Program Files (x86)/GRASS GIS 7.0.0/grass70.bat'*
*location = "MODIS_GUIWAGOU"*
*mapset = "GUIWAGOU"*
File "F:\PYTHON\PYTHON_GRASS7.py", line 81, in <module>
for rast in grass.list_strings(type = 'rast'):
File "C:\Program Files (x86)\GRASS GIS
7.0.0\etc\python\grass\script\core.py", line 1110, in list_strings
7.0.0\etc\python\grass\script\core.py", line 427, in read_command
7.0.0\etc\python\grass\script\core.py", line 310, in handle_errors
CalledModuleError: Module run None ['g.list', '--q', '-m', 'type=rast']
ended with error
(error) output.
It should be type='raster', not type='rast' when calling g.list or its
interface list_strings
Anna
Do you know what's wrong?
Best,
Xiaoye
grass-user mailing list
grass-user@lists.osgeo.org
