[GRASS-user] Working with NTF files
Hi list & apologies for cross-posting.
In short,
I am trying to handle ntf files (NITF) as easy as possible -- working with
some WorldView 01/02 and QuickBird imagery.
1) The question is: how do you correctly import in GRASS-GIS QuickBird &
WorldView imagery from N(I)TF containers?
2) A second, of less importance, question, is: how important are the warnings
like: "Warning 1: Unable to save auxilary information in
/vsisubfile/3884_471349721,10APR13WV020600013APR10075059-
P1BS-500060446050_05_P003.ntf.aux.xml." ?
My working solution (seems to be),
is to gdal-warp the SUBDATASET that contains the raster spectral bands _and_
by using the -rpc switch (mentioned in some past post in GDAL-dev's ML [19]).
Otherwise, the resulting warped image is heavily skewed and not ready for
analysis. E.g.:
gdalwarp -rpc NITF_IM:0:10APR13WV020600013APR10075059-
P1BS-500060446050_05_P003.ntf 10APR13WV020600013APR10075059-
P1BS-500060446050_05_P003_NorthUp.tif
This post is, also, sort of a BUMP related to my previous latest message in
the GDAL-dev-ML's thread entitled "Can't read NITF images" :-! I think that
N(I)TF files, no matter whatsoever the status of the related drivers are, as
well as the "feelings" towards favouring it or not, deserves some more
examples, a page in GRASS-Wiki perhaps, etc.
Now, the long story is that,
I 've been through the list (grass-user, gdal-dev), manuals (grass importing
related stuff & gdal's driver's documentation), well known and easy to find
pages in GRASS-Wiki, GDAL tutorials, etc. I haven't found any concrete
examples on working with NITF images and GFOSS. [**See various links in the
end]
I would appreciate any hints (while I am actively searching How To do this
best) to save time in the quest to find an optimal solution which can be
scripted to handle various images from the same source. Unfortunately, there
is no access in GeoTiffs (so far/yet)!
Set aside the internal compression "obstacle" (JPEG2000) which one can
overcome using the OpenJPEG driver (or, necessarily some proprietary (?) bound
solution [0, 1, 2, 3]), NITF files that contain multiple SUBDATASETS may look
like:
# code ###################################################
gdalinfo -nomd -norat -noct -nofl 10APR13WV020600013APR10075059-
Driver: NITF/National Imagery Transmission Format
Files: 10APR13WV020600013APR10075059-P1BS-500060446050_05_P003.ntf
Size is 35840, 27648
Coordinate System is `'
GCP Projection =
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        TOWGS84[0,0,0,0,0,0,0],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0,
        AUTHORITY["EPSG","8901"]],
    UNIT["degree",0.0174532925199433,
        AUTHORITY["EPSG","9108"]],
    AUTHORITY["EPSG","4326"]]
GCP[ 0]: Id=UpperLeft, Info=
          (0.5,0.5) -> (43.8088888888889,-23.3544444444444,0)
GCP[ 1]: Id=UpperRight, Info=
          (35839.5,0.5) -> (43.6219444444444,-23.3344444444444,0)
GCP[ 2]: Id=LowerRight, Info=
          (35839.5,27647.5) -> (43.6225,-23.1958333333333,0)
GCP[ 3]: Id=LowerLeft, Info=
          (0.5,27647.5) -> (43.8083333333333,-23.2152777777778,0)
Subdatasets:
  SUBDATASET_1_NAME=NITF_IM:0:10APR13WV020600013APR10075059-
  SUBDATASET_1_DESC=Image 1 of 10APR13WV020600013APR10075059-
  SUBDATASET_2_NAME=NITF_IM:1:10APR13WV020600013APR10075059-
  SUBDATASET_2_DESC=Image 2 of 10APR13WV020600013APR10075059-
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0,27648.0)
Upper Right (35840.0, 0.0)
Lower Right (35840.0,27648.0)
Center (17920.0,13824.0)
Band 1 Block=1024x1024 Type=UInt16, ColorInterp=Gray
  Overviews: 17920x13824, 8960x6912, 4480x3456, 2240x1728, 1120x864
  Overviews: arbitrary
The 1st SUBDATASET is reported as:
gdalinfo -sd 1 -nomd -norat -noct -nofl 10APR13WV020600013APR10075059-
[ -- cut -- some Warnings -- ]
GCP Projection =
GEOGCS["WGS 84",
    DATUM["WGS_1984",
Corner Coordinates:
The 2nd SUBDATASET is reported as:
gdalinfo -sd 2 -nomd -norat -noct -nofl 10APR13WV020600013APR10075059-
Size is 97, 78
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
GeoTransform =
  43.8096587433111, -0.001954571759259283, -1.803751803795437e-06
  -23.35525135093495, 0.0002068865740741814, 0.001823593073593144
Corner Coordinates:
Upper Left ( 43.8096587, -23.3552514) ( 43d48'34.77"E, 23d21'18.90"S)
Lower Left ( 43.8095181, -23.2130111) ( 43d48'34.26"E, 23d12'46.84"S)
Upper Right ( 43.6200653, -23.3351834) ( 43d37'12.24"E, 23d20' 6.66"S)
Lower Right ( 43.6199246, -23.1929431) ( 43d37'11.73"E, 23d11'34.60"S)
Center ( 43.7147917, -23.2740972) ( 43d42'53.25"E, 23d16'26.75"S)
Band 1 Block=97x1 Type=Byte, ColorInterp=Undefined
Likewise, reporting on a Multi-Spectral NTF container, the 2nd SUBDATASET is
the Spatial Reference System information.
Unfortunately, though expected, r.in.gdal complains about the missing
projection info for the 1st SUBDATASET.
r.in.gdal in=NITF_IM:0:10APR13WV020600013APR10075059-
P1BS-500060446050_05_P003.ntf out=m_sd_1
ERROR: Projection of dataset does not appear to match current location.
       Location PROJ_INFO is:
       proj: ll
       datum: wgs84
       ellps: wgs84
       no_defs: defined
       Import dataset PROJ_INFO is:
       cellhd.proj = 0 (unreferenced/unknown)
       You can use the -o flag to r.in.gdal to override this check and use
       the location definition for the dataset.
       Consider generating a new location from the input dataset using the
       'location' parameter.
Adding the "-o" flag, gets to the next error:
P1BS-500060446050_05_P003.ntf out=m_sd_1 -o
WARNING: Over-riding projection check
ERROR: Illegal latitude for North
Adding the "-l" switch, takes too much time "waiting" in 0% for the import
process. Now, the GCP's are given in the 2nd SUBDATASET(s). Is there any way
to avoid usnig "r.region" and make the long story short, just by using some
gdal-* magic?
Using gdalwarp to go NorthUp:
#################################################### code #
gdalwarp -of NITF -co "ICORDS=G" NITF_IM:0:10APR13WV020600013APR10075059-
P1BS-500060446050_05_P003_NorthUp.ntf
allows for imoprting the image via r.in.gdal. However, this image is
obviously and heavily skewed/shifted. Using r.region doesn't make any
sense...
since the image boundaries coincide!
gdalinfo -nomd -noct -norat -nofl -nogcp 10APR13WV020600013APR10075059-
M1BS-500060446050_05_P003_NorthUp.tif
Corner Coordinates:
Upper Left ( 43.6218649, -23.1956837) ( 43d37'18.71"E, 23d11'44.46"S)
Lower Left ( 43.6218649, -23.3543246) ( 43d37'18.71"E, 23d21'15.57"S)
Upper Right ( 43.8088360, -23.1956837) ( 43d48'31.81"E, 23d11'44.46"S)
Lower Right ( 43.8088360, -23.3543246) ( 43d48'31.81"E, 23d21'15.57"S)
and minor differences when gdal-warping in to a NITF file
Corner Coordinates:
Upper Left ( 43.6219339, -23.1955450) ( 43d37'18.96"E, 23d11'43.96"S)
Lower Left ( 43.6219339, -23.3544550) ( 43d37'18.96"E, 23d21'16.04"S)
Upper Right ( 43.8088994, -23.1955450) ( 43d48'32.04"E, 23d11'43.96"S)
Lower Right ( 43.8088994, -23.3544550) ( 43d48'32.04"E, 23d21'16.04"S)
After importing, one band reports
r.info -g M1BS_from_TIF.1
north=-23.1956836847222
south=-23.3543246272222
east=43.8088360363889
west=43.6218648544444
The corner coordinates are practically identical. Hence, it doesn't look like
boundary (re-)definition/correction is required for these rasters.
So, how do you go about your NITF images?
The only "nice-working" attempt so far, is when I extacted a specific fragment
out of the Multi-Spectral container, for example, using the "-te" switch while
warping, i.e. (using values, of course, in place of West, South, North and
East):
gdalwarp -s_srs 'epsg:4326' -te West South North East
03APR13WV010500013APR03073141-P1BS-500060446050_03_P003.ntf test.tif
These small fragments coincide perfectly with some vectorised area of intere
st.
And, finally, and fortunately, adding the "-rpc" magic, seems to do the trick.
Importing an rpc-warped image in GRASS, looks, after some cross-checks, nice
:slight_smile:
Any other solutions?
Thanks, Nikos
[0]
<http://www.jpeg.org/faq.phtml?action=show_answer&question_id=q3f042a68b1081&gt;
[1] <http://trac.osgeo.org/gdal/wiki/ECW&gt;
[2] <http://trac.osgeo.org/gdal/wiki/JasPer&gt;
[3] <http://trac.osgeo.org/gdal/wiki/JP2KAK&gt;
[4] <http://trac.osgeo.org/gdal/wiki/MrSID&gt;
NITF and GDAL
[5] <http://www.gdal.org/frmt_nitf.html&gt;
[6] <http://www.gdal.org/frmt_nitf_advanced.html&gt;
NITF Related posts (even a bit)
[7] <http://lists.maptools.org/pipermail/fwtools/2008-March/001193.html&gt;,
2008, refers also to license stuff.
[8] <http://osgeo-org.1560.x6.nabble.com/gdal-dev-Can-t-read-NITF-image-td5064590.html&gt;
[9] <http://lists.osgeo.org/pipermail/gdal-dev/2012-April/032431.html&gt;
[10] <http://web.archiveorange.com/archive/v/H2CPnHaFxXHV9S1zxqmE&gt;
[11] <http://lists.osgeo.org/pipermail/grass-user/2000-May/003502.html&gt;, very
old!
[12] <http://lists.osgeo.org/pipermail/grass-user/2006-March/033353.html&gt;, old
[13] <http://lists.osgeo.org/pipermail/grass-user/2006-March/033300.html&gt;, old
[14] <http://osgeo-org.1560.x6.nabble.com/gdal-dev-NITF-with-MultiDataSet-td5050649.html&gt;, "Try building a vrt with the NITF datasets."
[15] <http://www.mail-archive.com/gdal-dev@lists.osgeo.org/msg02376.html&gt;,
refers to "-co".
[16] <http://marc.info/?l=gdal-dev&m=121323053222339&w=2&gt;
[17] <http://osdir.com/ml/gdal-development-gis-osgeo/2009-01/msg00044.html&gt;,
about compression/compressed output.
Advanced coding discussions
[18] <http://osgeo-org.1560.x6.nabble.com/NITF-image-metadata-domain-field-in-GDAL-SUBDATASETS-td3762940.html&gt;
[19] <http://osgeo-org.1560.x6.nabble.com/gdal-dev-How-to-use-RPC-Metadata-from-NITF-Files-in-a-MapServer-TileIndex-td4981951.html&gt;, "The images also
have rpc metadata and using the -rpc option in gdalwarp reprojects them quite
well."
On Sun, Jul 14, 2013 at 2:53 PM, Nikos Alexandris
In short,
Nikos,
Your working solution with gdalwarp seems reasonable. Is there a problem
with it? Perhaps you were hoping to do the RPC based warp within GRASS?
warnings
This is not important. I presume you are getting this with JPEG2000
compressed
image streams in NITF? If you file a bug I might be able to clear this up
but there
are layers of complexity that make it challening.
_and_
[19]).
analysis. E.g.:
that
as
I'm afraid I'm one of those who neglected that thread. I thought I saw Even
answer is so I was happy to keep out of it.
I can't speak to how the files should be described in GRASS. Generally
I'd hope that the value of using GDAL is that GRASS wouldn't need to
talk too much about specific formats.
On the GDAL side we often have special info in trac wiki pages under the
BuildHints page, but in this case the issues are more usage rather than
building so there is no obvious place for user contributions. The format
pages for NITF do have quite a bit of info. It is (I think) the only driver
with an "advanced" page. However, there are many kinds of NITF
files and thus usage patterns that are an issue so it isn't clear how to
handle that in the user docs.
I've skimmed the rest of your post, but I don't have any particular
advice or anything to add. I do think it is reasonable to correct
such images into a nicer form with gdalwarp before running r.in.gdal.
Best regards,
Frank
importing
end]
there
bound
look
like:
GCP Projection =
GEOGCS["WGS 84",
    DATUM["WGS_1984",
Subdatasets:
Corner Coordinates:
GCP Projection =
GEOGCS["WGS 84",
    DATUM["WGS_1984",
Corner Coordinates:
Size is 97, 78
GEOGCS["WGS 84",
    DATUM["WGS_1984",
GeoTransform =
Corner Coordinates:
is
       proj: ll
       datum: wgs84
       ellps: wgs84
       no_defs: defined
way
gdal-* magic?
sense...
Corner Coordinates:
Corner Coordinates:
like
fragment
while
East):
intere
st.
trick.
nice
:slight_smile:
Thanks, Nikos
[0]
NITF and GDAL
[8] <
very
old!
old
old
[14] <
refers to "-co".
[18] <
[19] <
"The images also
quite
well."
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | Geospatial Software Developer
Nikos Alexandris:
with it?
No (except that I left this option as the "final attempt" of many tests --
working with some >1GB images here, so it took me hours... :D). Your
confirmation, though, is highly useful!
Yes, I was hopping to say something like:
r.in.gdal in=NITF.ntf out=NITF sds=1 band=1,2,3,4 transform=rpc[,tps]
[resampling=n,b,c,cs,l,a,m]
:smiley: -- I know, I am asking for too much. I have read the following post
already: <http://fwarmerdam.blogspot.gr/2009/12/death-by-complexity.html&gt;\.
Also, there is already a (kind of related) grass-ticket:
<http://trac.osgeo.org/grass/ticket/798&gt;\.
> warnings like: "Warning 1: Unable to save auxilary information in
compressed image streams in NITF?
Correct
If you file a bug I might be able to clear this up but there are layers of
I will (take the time later to) file a ticket. I was hopping, anyhow, in case
such warnings are not a real big deal, to have a way to supress them. That
would ease off, me thinks at least, scripting. Some option like the "-q" one
-- though, in this case it doesn't silence these Warnings.
> My working solution (seems to be), is to gdal-warp the SUBDATASET that
> contains the raster spectral bands _and_ by using the -rpc switch
> (mentioned in some past post in GDAL-dev's ML [19]). Otherwise, the
> resulting warped image is heavily skewed and not ready for analysis.
> E.g.:
> in the GDAL-dev-ML's thread entitled "Can't read NITF images" :-! I
> think that N(I)TF files, no matter whatsoever the status of the related
> drivers are, as well as the "feelings" towards favouring it or not,
> deserves some more examples, a page in GRASS-Wiki perhaps, etc.
It certainly is so (in general).
I am (slowly) getting to see that there is a "bigger" picture.
Your reply as a whole is very useful for me.
Thank you Frank, Nikos
[rest deleted]
On Mon, Jul 15, 2013 at 1:52 AM, Nikos Alexandris
<nik@nikosalexandris.net> wrote:
Nikos Alexandris:
This is mixing different concepts, i.e. import and georeferencing. You
can use i.rectify after importing raster data. RPC is not supported by
GRASS, thus the gdalwarp approach is most probably the preferred
solution. In good GRASS tradition, you could also figure out a
reasonable target grid geometry and set this with the corresponding
option to gdalwarp.
Markus M
Frank Warmerdam:
Nikos Alexandris:
( Yeah, right... hopping :smiley: )
Markus Metz:
option to gdalwarp.
Ok -- On/Off: would it make sense to be able to say
grass -c Some_NITF_Container /grassdb/Location_Based_On_NITF
and, if need be, select the SDS that contains/is the SRS, i.e.
grass -c Some_NITF_Container /grassdb/Location_Based_On_NITF sds=2
Nikos
Nikos A:
Eli Adam wrote:
Sometimes to avoid materializing large intermediate datasets on disk, a VRT
can be used. I'm not sure if this would be useful in your case.
Right, in theory it is extremely useful. Dunno if it'll work. In my To Do
list... :slight_smile:
Frank W:
> driver with an "advanced" page. However, there are many kinds of NITF
I and others have put GDAL usage notes here,
http://trac.osgeo.org/gdal/wiki/CodeSnippets
Thank you, Nikos
On Tue, Jul 16, 2013 at 12:34 PM, Nikos Alexandris
Markus Metz:
option to gdalwarp.
You probably mean
grass -c Some_GDAL/OGR_recognized_Container
/grassdb/Location_Based_On_GDAL/OGR_recognized_dataset
which is already possible.
No, for e.g. hdf and NITF you can specify the sds directly, no need to
have a sds= option.
In general, grass -c <geofile> would use the SRS of the geodataset,
not the SRS of the embedded GCPs or any other geotransform
information. Transformation/georeferencing would be done after import
with i.rectify or before import with gdalwarp.
Markus M
Markus Metz:
>> option to gdalwarp.
Nikos Alexandris:
Markus Metz wrote:
You probably mean
Absolutely.
Is it (always)? Please, see below whenever time permits.
have a sds= option.
which is? The one that gdalinfo reports on top, right?
Got it. I, think, I have a problem then...
Working with
# GDAL
gdal-config --version
1.10.0
# which?
which gdal-config
/usr/bin/gdal-config
# formats:
gdalinfo --formats | grep NI
  NITF (rw+vs): National Imagery Transmission Format
# grass?
g.version -bg
version=7.0.svn
date=2013
revision=57074
build_date=2013-06-12
./configure --with-cxx --with-includes=/usr/include/ --with-libs=/usr/lib64/
--with-proj --with-proj-includes=/usr/include/ --with-proj-libs=/usr/lib64/ --
with-proj-share=/usr/share/proj/ --with-geos --with-geos=/usr/bin/geos-config
--with-gdal=/usr/bin/gdal-config --with-x --with-motif --with-cairo --with-
opengl-libs=/usr/include/GL --without-ffmpeg --with-python=yes --with-
python=/usr/bin/python2.7-config --with-wxwidgets --with-freetype=yes --with-
freetype-includes=/usr/include/freetype2/ --with-odbc=yes --with-sqlite=yes --
with-mysql=yes --with-mysql-includes=/usr/include/mysql --with-mysql-
libs=/usr/lib/mysql --with-postgres=yes --with-postgresql=yes --with-postgres-
includes=/usr/include/postgresql --with-opencl --with-openmp --with-pthread --
with-lapack --with-fftw --with-readline --with-regex --with-nls --with-jpeg --
with-tiff --with-png --with-netcdf --without-opendwg --enable-largefile=yes
Consider the following example
# below, obviously not epsg=4326, but UTM 37S
gdalinfo -proj4 -nogcp -nomd -norat -noct -nofl
15JUN11IK0101000po_697515_pan_0000000.ntf
Files: 15JUN11IK0101000po_697515_pan_0000000.ntf
Size is 13768, 44528
PROJCS["unnamed",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
        AUTHORITY["EPSG","4326"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",39],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",10000000]]
PROJ.4 string is:
'+proj=utm +zone=37 +south +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m
+no_defs '
Origin = (545471.000000000000000,9533235.000000000000000)
Pixel Size = (1.000000000000000,-1.000000000000000)
Corner Coordinates:
Upper Left ( 545471.000, 9533235.000) ( 39d24'35.06"E, 4d13'22.02"S)
Lower Left ( 545471.000, 9488707.000) ( 39d24'35.85"E, 4d37'32.19"S)
Upper Right ( 559239.000, 9533235.000) ( 39d32' 1.67"E, 4d13'21.75"S)
Lower Right ( 559239.000, 9488707.000) ( 39d32' 2.71"E, 4d37'31.89"S)
Center ( 552355.000, 9510971.000) ( 39d28'18.81"E, 4d25'26.98"S)
Band 1 Block=1024x1024 Type=UInt16, ColorInterp=Undefined
  Min=0.000 Max=2047.000
  Minimum=0.000, Maximum=2047.000, Mean=392.957, StdDev=204.156
# use it
grass7 -c 15JUN11IK0101000po_697515_pan_0000000.tif /geo/grassdb/Location_Pan
# where am I in?
g.gisenv
MAPSET=PERMANENT
GISDBASE=/geo/grassdb
LOCATION_NAME=Location_Pan
GUI=text
# where?
g.proj -p
-PROJ_INFO-------------------------------------------------
proj : ll
datum : wgs84
ellps : wgs84
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : degree
units : degrees
meters : 1.0
This is not correct, is it?
Then, reporting on _all_ multi-spectral bands like
gdalinfo -proj4 -nogcp -nomd -norat -noct -nofl po_697515_red_0000000.ntf |
grep proj
returns
+no_defs '
Using each of the MS bands to create a Location, gives
g.proj -p
XY location (unprojected)
Best, Nikos
On Tue, Jul 16, 2013 at 2:10 PM, Nikos Alexandris
Markus Metz:
>> option to gdalwarp.
Nikos Alexandris:
Markus Metz wrote:
You probably mean
Absolutely.
It should be possible.
have a sds= option.
Yes, or ogrinfo.
The projection as recognized by GRASS is indeed different from the one
reported by GDAL.
What says g.proj georef=your_geofile -p?
What reports r.in.gdal when trying to import in a location that
definitively does not match the SRS?
Both tests should be done both with the NITF file and with a
subdataset of the NITF file.
Markus M
Working with
# GDAL
1.10.0
# which?
which gdal-config
# formats:
# grass?
g.version -bg
version=7.0.svn
date=2013
revision=57074
PROJCS["unnamed",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
PROJ.4 string is:
+no_defs '
Corner Coordinates:
# use it
# where am I in?
g.gisenv
MAPSET=PERMANENT
GUI=text
# where?
g.proj -p
proj : ll
datum : wgs84
ellps : wgs84
no_defs : defined
unit : degree
units : degrees
meters : 1.0
grep proj
returns
+no_defs '
g.proj -p
Best, Nikos
Markus Metz:
[almost all previous discussion erased]
Following a test using an IKONOS-NTF set of files – they do not contain SUBDATASETS. Actually, the same files as in my last/previous post. Will re-test also for a NITF container that includes SUBDATASETs.
That’s a very nice parameter which I never thought of to combine with “-p” :slight_smile:
,—8<–
g.proj -p georef=15JUN11IK0101000po_697515_pan_0000000.ntf
Trying to open with OGR…
…succeeded.
WARNING: Read of file 15JUN11IK0101000po_697515_pan_0000000.ntf was
successful, but it did not contain projection information. 'XY
(unprojected)’ will be used
This is however 1) strange – it misses a message like “Trying to open with GDAL…” and 2) (successively) not true because gdalinfo reports:
,—8<–
gdalinfo -proj4 -nomd -noct -nogcp 15JUN11IK0101000po_697515_pan_0000000.ntf | grep proj
'+proj=utm +zone=37 +south +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs ’
Exactly the same happens (as above) for the multi-spectral bands. A bug? Using this file in
“grass7 -c 15JUN11IK0101000po_697515_pan_0000000.tif /grassdb/test_Location”
creates the following Location:
g.proj -p
proj : ll
datum : wgs84
ellps : wgs84
no_defs : defined
unit : degree
units : degrees
meters : 1.0
Now, r.in.gdal seems to correctly recognise the SRS!
,—8<–
r.in.gdal in=15JUN11IK0101000po_697515_pan_0000000.ntf out=import_test_15JUN11IK0101000po_697515_pan_0000000.ntf
proj: ll
datum: wgs84
ellps: wgs84
no_defs: defined
Dataset PROJ_INFO is:
name: Universal Transverse Mercator
proj: utm
datum: wgs84
ellps: wgs84
zone: 37
south: defined
towgs84: 0,0,0,0,0,0,0
no_defs: defined
ERROR:
‘location’ parameter.
Not applicable in this case, no SUBDATASETs in these file(s).
Nikos
On Sat, Jul 20, 2013 at 9:20 PM, Nikos Alexandris
1)
Trying to open with OGR...
...succeeded.
(unprojected)' will be used
This is however 1) strange -- it misses a message like "Trying to open with
GDAL..." and 2) (successively) not true because gdalinfo reports:
g.proj first tries to open the geofile with OGR, if that fails, it
tries to open it with GDAL. Apparently OGR found a driver with which
it could successfully open the geofile. This might be a bug in OGR
(Frank?).
Using this file in
"grass7 -c 15JUN11IK0101000po_697515_pan_0000000.tif /grassdb/test_Location"
g.proj -p
proj : ll
datum : wgs84
ellps : wgs84
no_defs : defined
unit : degree
units : degrees
meters : 1.0
grass7 -c uses g.proj to create a location, thus the resulting
projection info of grass7 -c and g.proj georef= should be identical.
2)
Good.
So it is either a bug in g.proj (even though the call to OGROpen()
succeeds) or in OGR.
Markus M
Nikos Alexandris:
> > with some WorldView 01/02 and QuickBird imagery.
Frank W:
Nikos A:
Correct
Done as http://trac.osgeo.org/gdal/ticket/5173
Nikos
Should I file for this a ticket in GRASS' trac first?
Nikos
1)
Nikos Alexandris:
> ...succeeded.
> (unprojected)' will be used XY location (unprojected)
> with GDAL..." and 2) (successively) not true because gdalinfo reports:
Markus M:
(Frank?).
Nikos A:
> Using this file in
> g.proj -p
> proj : ll
> datum : wgs84
> ellps : wgs84
> no_defs : defined
> unit : degree
> units : degrees
> meters : 1.0
Markus M:
2)
Markus M:
Nikos A:
Markus M:
Good. So it is either a bug in g.proj (even though the call to OGROpen()
Yet another NITF related "problem". An ntf file contains (no SUBDATASETS)
gdalinfo -nogcp -nomd -mm M1BS.ntf
Band 1 Block=1024x1024 Type=UInt16, ColorInterp=Blue
    Computed Min/Max=183.000,2047.000
  Overviews: 3438x3448, 1719x1724, 859x862, 429x431, 214x215
Band 2 Block=1024x1024 Type=UInt16, ColorInterp=Green
    Computed Min/Max=252.000,2047.000
Band 3 Block=1024x1024 Type=UInt16, ColorInterp=Red
    Computed Min/Max=86.000,2047.000
Band 4 Block=1024x1024 Type=UInt16, ColorInterp=Alpha
    Computed Min/Max=50.000,2047.000
Attempting to warp the data with the -rpc switch and convert to GeoTIFF,
begins with
"Using band 4 of source image as alpha."
This results in an "empty" NIR band in the GeoTIFF file.
Band 1 Block=6728x1 Type=UInt16, ColorInterp=Gray
    Computed Min/Max=0.000,2047.000
Band 2 Block=6728x1 Type=UInt16, ColorInterp=Undefined
Band 3 Block=6728x1 Type=UInt16, ColorInterp=Undefined
Band 4 Block=6728x1 Type=UInt16, ColorInterp=Undefined
    Computed Min/Max=0.000,0.000
No success using '-co "ALPHA=NO"'. Same "problem" when using gdal_translate
on the whole ntf file. However, instructing
gdal_translate -b 4 M1BS.ntf b4.tif
gives
gdalinfo -nogcp -nomd -mm b4.tif
Band 1 Block=6876x1 Type=UInt16, ColorInterp=Gray
But, this is not "fine". How is this to be done correctly, RPC-based warping
and conversion in one go?
Thanks, Nikos
begins with
gives
Related thread/solution:
http://lists.osgeo.org/pipermail/gdal-dev/2012-December/034984.html
Translating to a VRT, band by band -- is it the only solution?
Nikos
