[GRASS-user] working with shapefiles
my problem is about topology and attribute storing :
(I work on Grass 6.3-cvs, connected to a postgresql database)
* I start from a line shapefile representing polygons boundaries,
* import it with v.in.ogr, and the option 'boundaries' ;
In order to build a topologically correct map, grass generates nodes at each boundary intersection, and it is actually what I want...
The problem is elsewhere : the source shapefile, non-topological, contains certain lines that are not splitted at intersections. So, let's say the original shape contains 340 lines, the imported map then will contain 385 boundaries. But the attribute table contains 340 records (340 categories).
For some reasons (exporting the table in an ascii format) I would like to have 385 records in the attribute table, that is in a way to duplicate certain records.
What would you suggest me to do ?
(my temporary and dirty solution was to export the boundaries in a line shapefile, then re-import it... not very clean)
Thank you !
Vincent
