Dear list
We have developed a Web Processing service for calculating catchment
outlines in UK using GRASS and PyWPS:
http://www.faunalia.co.uk/catchmentfinder
Any feedback is appreciated.
Regards
Saber
Dear list
Regards
Saber
Valentin
Many thanks for your feed back.
The DTM is quite old (over 20 years) and very coarse (50 metre..but grass
region setting is I think 100 metre).
The reason you don't see the point is that it doesn't use the point and it
uses another one snapped to the stream (r.watershed output). But we
definitely add something to show the point, either user input or the
snapped one.
In terms of validation, we have Flood Estimation Handbook which
unfortunately is not free and using the same DTM in our WPS. For copyright
reasons there is no vector output from FEH either. So you need to create
screenshots. I don't have a license for it.
There will be more bells and whistles to it (hydrological parameters:
urban extent, main drain slope, max min elevation, etc).
Saber
Nice tool, I like it!
Three things came up in my mind when I used it.
1) After I selected a point and press calculate I couldn't see any more
the point I selected...2) It seams like there are some wrong calculation. For example for the
randomly chosen point (527714, 328638). And the catchment border could
be a little smoother3) I can only select a visual point, it would be nice to select the
point by coordinates... it would be more useful.Did you try to validate your data with a independent dataset? I know
from France there exists free hydrological surface catchments shapes
over the whole country maybe it possible to make a validation with
public DEM-data like SRTM.regards Valentin
On Oct 26, 2011 9:27 AM, "Saber Razmjooei" <razmjooeis@faunalia.co.uk
<mailto:razmjooeis@faunalia.co.uk>> wrote:Dear list
outlines in UK using GRASS and PyWPS:http://www.faunalia.co.uk/catchmentfinder
Regards
Saber_______________________________________________
grass-user mailing list
grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
Dear Valentin
Thanks for your through inspection. That part of UK is flat with lots of
artificial drains and canals. There is a loop river and also 2 parallel
channel. The DTM doesn't look great either and I think streams have not
been extracted properly in r.watershed.
Saber
On 26/10/11 21:07, Valentin Wittich wrote:
Hi Saber,
could you recreate the wrong calculation I've get with the point
(527714, 328638). The point is a little above the connection to the
tributary, could it be that the snap function doesn't work proper?V.
On 10/26/2011 12:08 PM, Saber Razmjooei wrote:
Valentin
grass
region setting is I think 100 metre).The reason you don't see the point is that it doesn't use the point
and it
snapped one.In terms of validation, we have Flood Estimation Handbook which
copyright
screenshots. I don't have a license for it.There will be more bells and whistles to it (hydrological parameters:
urban extent, main drain slope, max min elevation, etc).Cheers
SaberNice tool, I like it!
On Oct 26, 2011 9:27 AM, "Saber Razmjooei"<razmjooeis@faunalia.co.uk
catchment
Regards
grass-user@lists.osgeo.org<mailto:grass-user@lists.osgeo.org>
