[GRASS-user] Wrangling CityGML with GRASS ?
Hello Markus, Stefan, all,
thanks for all your advice. New challenges have emerged, as the dataset is defined as a polyhedral surface:
I upgraded to GRASS 7.6.1 which comes with GDAL 2.3.1.
The data sources are official CityGML files provided by the German Federal Agency for Cartographyand Geodesy (Bundesamt für Kartographie), which have an ".xml"-extension.
v.in.ogr -2 -o --o input=TEST.xml output=TEST01
throws several warnings and creates an empty vector without an points/lines in it:
Warning 1: Unrecognized geometry type : 1015 [<=== note this!]
No projection information available for layer <Building>
Übersteuere die Überprüfung der Projektion.
Check if OGR layer <Building> contains polygons...
100%
WARNUNG: Vektorkarte <SMALL01> existiert bereits und wird überschrieben.
Creating attribute table for layer <Building>...
Importing 1 features (OGR layer <Building>)...
WARNUNG: Skipping unsupported geometry type 'POLYHEDRALSURFACE' [<=== note this!]
100%
Erstelle Topologie für die Vektorkarte <SMALL01@PERMANENT>...
Registriere Primitive...
WARNUNG: Input data contains 3D features. Created vector is 2D only,
         disable -2 flag to import 3D vector.
This problem seems to be ogr/gdal related:
ogrinfo -al TEST.xml
describes the geometry as a POLYHEDRALSURFACE Z (((412033.466 5812969.869 ...))).
ogr2ogr -f "GML" TEST.gml TEST.xml fails (some effect when trying other target formats like CSV or ESRI shape:
ERROR 6: Unsupported geometry type 3D PolyhedralSurface
ERROR 1: Export of geometry to GML failed
ERROR 1: Terminating translation prematurely after failed
translation of layer Building (use -skipfailures to skip errors)
There is GDAL documentation about surfaces (https://gdal.org/development/rfc/rfc64_triangle_polyhedralsurface_tin.html), but I couldn't find anything about transformations/pruning from 3D to 2D.
The CGAL library appears to be capable to handle such surfaces, but GIS-integration seems to be limited (https://www.cgal.org/).
Ideas on how to proceed, anyone ?
best,
Peter
<peter.loewe@gmx.de>
Gesendet: Dienstag, 06. August 2019 um 14:46 Uhr
Von: grass-user-request@lists.osgeo.org
An: grass-user@lists.osgeo.org
Betreff: grass-user Digest, Vol 160, Issue 5
Send grass-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
  grass-user-owner@lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of grass-user digest..."
Today's Topics:
   1. Re: Problems starting grass 7.4.1 in ubuntu (Markus Metz)
   2. Re: wms google (Micha Silver)
   3. Re: Wrangling CityGML with GRASS ? (Stefan Blumentrath)
   4. Re: Wrangling CityGML with GRASS ? (Peter Löwe)
   5. Re: Wrangling CityGML with GRASS ? (Markus Metz)
Message: 1
Date: Mon, 5 Aug 2019 22:32:12 +0200
To: Sebastián Dietrich <sebadietrich@gmail.com>
Cc: grass-user <grass-user@lists.osgeo.org>
Subject: Re: [GRASS-user] Problems starting grass 7.4.1 in ubuntu
Message-ID:
  <CAG+h=FGejQGA8neHu3Sf_hSA6YNSNkOZVDUL1zck8Fk8uM2Gzw@mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
On Mon, Aug 5, 2019 at 5:35 PM Sebastián Dietrich <sebadietrich@gmail.com>
wrote:
> Hi everyone, when i try to launch g.gui i get the following message:
> GRASS 7.4.1 (EPSG5344):~/Documentos/grassdata > g.gui
> Lanzando GUI <wxpython> en el fondo, por favor espere...
> Traceback (most recent call last):
> File "/usr/lib/grass74/gui/wxpython/wxgui.py", line 25, in <module>
> from core import globalvar
> File "/usr/lib/grass74/gui/wxpython/core/globalvar.py", line 39, in
<module>
> 'locale')).ugettext
> AttributeError: 'GNUTranslations' object has no attribute 'ugettext'
> [MÁSCARA ráster presente]
> Can someone help with this issue?
GNUTranslations has an attribute ugettext only in Python2, not in Python3.
Make sure that the link "python" points to "python2", test with "python
--version"
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190805/c9190edf/attachment-0001.html&gt;
Message: 2
Date: Tue, 6 Aug 2019 09:19:31 +0300
Cc: Ken Mankoff <mankoff@gmail.com>, grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] wms google
Message-ID: <73c1d605-3729-ab98-2f81-096d4a8d20b7@gmail.com>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190806/002e1069/attachment-0001.html&gt;
Message: 3
Date: Tue, 6 Aug 2019 09:13:57 +0000
From: Stefan Blumentrath <Stefan.Blumentrath@nina.no>
To: "Peter Löwe" <peter.loewe@gmx.de>, "grass-user@lists.osgeo.org"
Subject: Re: [GRASS-user] Wrangling CityGML with GRASS ?
Message-ID:
  <HE1PR0201MB21405732C039676E8A785D9C9ED50@HE1PR0201MB2140.eurprd02.prod.outlook.com>
Hi Peter,
Not personally...
I would guess you would import CityGML through GDAL:
https://3d.bk.tudelft.nl/svitalis/citygml/gdal/2017/07/24/messing-around-with-citygml-on-gdal-2.2.html
There you can create subsets and the like...
What are you planning to do with it, roughly?
Stefan
-----Original Message-----
From: grass-user <grass-user-bounces@lists.osgeo.org> On Behalf Of "Peter Löwe"
Sent: torsdag 1. august 2019 11:10
To: grass-user@lists.osgeo.org
Subject: [GRASS-user] Wrangling CityGML with GRASS ?
Hi list,
I'm looking for information/howtos/etc. about how to deal with large CityGML data sets using GRASS.
Has anybody already explored this ?
Best,
Peter
Message: 4
Date: Tue, 6 Aug 2019 12:23:29 +0200
To: "Stefan Blumentrath" <Stefan.Blumentrath@nina.no>
Cc: "grass-user@lists.osgeo.org" <grass-user@lists.osgeo.org>
Message-ID:
  <trinity-c2c845f5-697c-4269-afaf-8be6360d44d9-1565087009741@3c-app-gmx-bs34>
Content-Type: text/plain; charset=UTF-8
Hi Stefan,
thanks for the link: That's also the latest information we found so far, except for several OSGeo conference recordings (e.g. https://doi.org/10.5446/40913 https://doi.org/10.5446/40694).
My colleagues have ingested CityGML datasets into R, which caused issues with the vector-topology for individual buildings. Also, we have to cope with significant amounts of CityGML datasets, which would require very large amounts of RAM, if the processing is done in R. Since GRASS locations are storage-effective AND GRASS handles vector topologies well, I had hoped that someone already explored this approach further :slight_smile:
If this should be not the case (yet) we'll gladly report at one of next years FOSS4G events.
Best,
peter
> Gesendet: Dienstag, 06. August 2019 um 11:13 Uhr
> Von: "Stefan Blumentrath" <Stefan.Blumentrath@nina.no>
> An: "Peter Löwe" <peter.loewe@gmx.de>, "grass-user@lists.osgeo.org" <grass-user@lists.osgeo.org>
> Betreff: RE: [GRASS-user] Wrangling CityGML with GRASS ?
> Hi Peter,
> Not personally...
> Cheers
> Stefan
> Hi list,
> Best,
> Peter
Message: 5
Date: Tue, 6 Aug 2019 14:45:50 +0200
To: Peter Löwe <peter.loewe@gmx.de>
Cc: Stefan Blumentrath <Stefan.Blumentrath@nina.no>,
Message-ID:
  <CAG+h=FEkahTTz_DCBcgM8+0GBaqmQ7P_eGLMaEndZigbTdAZ4Q@mail.gmail.com>
Hi Peter,
On Tue, Aug 6, 2019 at 12:23 PM "Peter Löwe" <peter.loewe@gmx.de> wrote:
> Hi Stefan,
GML and GMLAS are supported by GDAL 2.2+. However, in order to import GMLAS
properly, some tricks are needed (interleaved reading for non-sequential
layers, see
https://gdal.org/drivers/vector/gmlas.html#performance-issues-with-large-multi-layer-gml-files)
which are built into GRASS 7.6+.
That's not related to the data format, but to the content: 3D polygons.
These are not supported in GRASS, when importing you need to convert the
data to 2D with v.in.ogr -2, otherwise you get corrupt topology. Maybe this
is also needed for R.
Markus M
> Best,
> peter
> > Hi Peter,
> > Not personally...
> > Cheers
> > Stefan
"Peter Löwe"
> > Hi list,
> > Best,
> > Peter
> > _______________________________________________
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190806/2dc10111/attachment.html&gt;
Subject: Digest Footer
End of grass-user Digest, Vol 160, Issue 5
The data sources are official CityGML files provided by the German Federal Agency for Cartographyand Geodesy (Bundesamt für Kartographie), which have an “.xml”-extension.
Check if OGR layer contains polygons…
100%
WARNUNG: Vektorkarte existiert bereits und wird überschrieben.
Creating attribute table for layer …
Importing 1 features (OGR layer )…
WARNUNG: Skipping unsupported geometry type ‘POLYHEDRALSURFACE’ [<=== note this!]
v.in.ogr could force-convert these polyhedral surfaces to multipolygons, at the risk of getting garbage.
The required change to v.in.ogr would be small, but it would be safer to skip these unsupported feature types in order to avoid garbage output.
Markus M
100%
Erstelle Topologie für die Vektorkarte SMALL01@PERMANENT
Registriere Primitive…
describes the geometry as a POLYHEDRALSURFACE Z (((412033.466 5812969.869 …))).
ogr2ogr -f “GML” TEST.gml TEST.xml fails (some effect when trying other target formats like CSV or ESRI shape:
There is GDAL documentation about surfaces (https://gdal.org/development/rfc/rfc64_triangle_polyhedralsurface_tin.html), but I couldn’t find anything about transformations/pruning from 3D to 2D.
best,
Peter
or, via email, send a message with subject or body ‘help’ to
than “Re: Contents of grass-user digest…”
Today’s Topics:
Message: 1
Message-ID:
Content-Type: text/plain; charset=“utf-8”
Lanzando GUI en el fondo, por favor espere…
File “/usr/lib/grass74/gui/wxpython/wxgui.py”, line 25, in
File “/usr/lib/grass74/gui/wxpython/core/globalvar.py”, line 39, in
‘locale’)).ugettext
AttributeError: ‘GNUTranslations’ object has no attribute ‘ugettext’
Make sure that the link “python” points to “python2”, test with “python
–version”
Markus M
An HTML attachment was scrubbed…
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190805/c9190edf/attachment-0001.html>
Message: 2
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190806/002e1069/attachment-0001.html>
Message: 3
To: “Peter Löwe” <peter.loewe@gmx.de>, “grass-user@lists.osgeo.org
Message-ID:
Hi Peter,
Not personally…
There you can create subsets and the like…
Stefan
From: grass-user <grass-user-bounces@lists.osgeo.org> On Behalf Of “Peter Löwe”
Hi list,
I’m looking for information/howtos/etc. about how to deal with large CityGML data sets using GRASS.
Best,
Peter
Message: 4
To: “Stefan Blumentrath” <Stefan.Blumentrath@nina.no>
Cc: “grass-user@lists.osgeo.org” <grass-user@lists.osgeo.org>
Message-ID:
Hi Stefan,
thanks for the link: That’s also the latest information we found so far, except for several OSGeo conference recordings (e.g. https://doi.org/10.5446/40913 https://doi.org/10.5446/40694).
If this should be not the case (yet) we’ll gladly report at one of next years FOSS4G events.
Best,
peter
Von: “Stefan Blumentrath” <Stefan.Blumentrath@nina.no>
An: “Peter Löwe” <peter.loewe@gmx.de>, “grass-user@lists.osgeo.org” <grass-user@lists.osgeo.org>
Hi Peter,
Not personally…
Stefan
Hi list,
Best,
Peter
Message: 5
Message-ID:
Hi Peter,
On Tue, Aug 6, 2019 at 12:23 PM “Peter Löwe” <peter.loewe@gmx.de> wrote:
Hi Stefan,
layers, see
That’s not related to the data format, but to the content: 3D polygons.
Markus M
Best,
peter
Hi Peter,
Not personally…
Stefan
“Peter Löwe”
Hi list,
Best,
Peter
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190806/2dc10111/attachment.html>
Hi Markus, all,
one option to deal with this is in a structured way could be to use the GMLAS-driver of GDAL, prior to the import into GRASS via v.in.ogr, as
Stelios Vitalis described it here: https://3d.bk.tudelft.nl/svitalis/citygml/gdal/2017/07/24/messing-around-with-citygml-on-gdal-2.2.html (last code example)
For me, GDAL2.3.1 in GRASS refuses to accept the “GMLAS:” override for the import-driver:
ogr2ogr -f GeoJSON SMALL.json GMLAS:SMALL.gml -oo REMOVE_UNUSED_LAYERS=YES -oo REMOVE_UNUSED_FIELDS=YES -sql “SELECT * FROM groundsurface”
→ if GDAL-4-GRASS is currently built without GMLAS-support, it would be wortwhile to include it soonish (-> benefits: https://inspire.ec.europa.eu/sites/default/files/presentations/gml_application_schema_made_easy_in_gdal_ogr_and_qgis_-_gmlas_driver_0.pdf)
Otherwise, the standard GML-driver doesn’t feature the REMOVE_xxx options:
ogr2ogr -f GeoJSON SMALL.json SMALL.gml -oo REMOVE_UNUSED_LAYERS=YES -oo REMOVE_UNUSED_FIELDS=YES -sql “SELECT * FROM groundsurface”
Warning 6: driver GML does not support open option REMOVE_UNUSED_LAYERS
Warning 6: driver GML does not support open option REMOVE_UNUSED_FIELDS
ERROR 6: The GeoJSON driver does not overwrite existing files.
ERROR 1: GeoJSON driver failed to create SMALL.json
Best,
peter
peter.loewe@gmx.de
Gesendet: Donnerstag, 08. August 2019 um 15:15 Uhr
Von: “Markus Metz” markus.metz.giswork@gmail.com
An: “Peter Löwe” peter.loewe@gmx.de
Cc: grass-user grass-user@lists.osgeo.org
Betreff: Re: [GRASS-user] Wrangling CityGML with GRASS ?
100%
Markus M
Hi Peter,
On Thu, Aug 8, 2019 at 3:56 PM “Peter Löwe” <peter.loewe@gmx.de> wrote:
Hi Markus, all,
from https://gdal.org/drivers/vector/gmlas.html: The driver requires Xerces-C >= 3.1
You need to rebuild GDAL accordingly, but
apparently GMLAS is supported. What is the exact error message for " GDAL2.3.1 in GRASS refuses to accept the “GMLAS:”"?
Markus M
Best,
peter
Von: “Markus Metz” <markus.metz.giswork@gmail.com>
100%
Markus M
Hi Markus,
I am not sure whether GMLAS is currently supported:
throws
"FAILURE:
Unable to open datasource GMLAS:SMALL.gml' with the following drivers. -> OGR_GRASS’
PCIDSK' -> PDF’
→ with no mentioning of GMLAS as a driver option.
Best,
Peter
Markus M
