[GRASS-user] wx georectifier
I'm a bit confused. How do you set the target locations/mapset with the wxGUI georeferencing tool?
I can exit out and use i.target from the menu after crating the group,
but only because I know it's there.
Hamish
Hi Hamish,
I have never used georectifier but QGIS (which can open GRASS mapsets) has a
good georeferencer, it georectifies to a tiff with a wrl file. may be worth
a look? Depends what you are trying to do.
Good luck
Gary
View this message in context: http://n2.nabble.com/wx-georectifier-tp4570015p4570128.html
