[GRASS-user] wx python: multiple selection
Hi.
Sorry for naive question, but in fact I try to use wx since few days, so maybe I lost something...
How to made multiple map selection in wx without repetition of choosing map from list
(look for something like control+click in tcltk menu gui)
when multiple scope of map is needed (for example r.to.rast3d, v.patch) manual method is little frustrating
cheers
J.
Hi Jarek,
I might be answering a bit late but here it goes....
I wxgui you can choose one raster map at a time. If the input is for
multiple maps it will add the map to the end of the list. So, the idea
is:
Click on the drop down menu arrow and choose raster 1
Click on drop down menu arrow again and choose raster 2
do this for as many rasters as you wish
Daniel
2010/7/23 Jarek Jasiewicz <jarekj@amu.edu.pl>:
Hi.
from list
cheers
J.
grass-user mailing list
grass-user@lists.osgeo.org
Daniel Victoria pisze:
Hi Jarek,
is:
Daniel
Hi Daniel,
I notice that!
It good solution when I need add 2-5 maps, no more
I only ask what about situation when I must add more than 40 maps in r.to.rast3d? In tcltk version I used CTRL + click to select necessary maps at once
So it means that such situation command must be created externally and next passed to terminal.
Jarek
Hi.
from list
cheers
J.
