Hello,
for digitizing convenience, I would like to change the default color of
currently digitized line/boundary. The default is red (dashed for
current segment) and this feature is not accessible via the digitizing
settings menu.
I am wondering where this color setting is stored, then if it is
possible to switch it directly in the source code.
Ok, this is a trivial concern but there might exist a quite straight
answer
Vincent
2012/3/7 Vincent Bain <bain@toraval.fr>:
settings menu.
could you try r50999 (trunk) or r51000 (devbr6)?
vdigit settings -> symbology -> digitize new line segment (digitizer
new line/boundary)
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Yep ! it works (tested on devbr6).
will it be possible to port it soon to 6.4 release branch ?
Thank you so much Martin for your promptness,
Vincent.
Le mercredi 07 mars 2012 à 11:57 +0100, Martin Landa a écrit :
> settings menu.
new line/boundary)
Martin
thanks for testing, done in r51017.
Martin
