Dear all,
when I try to display in Preview mode the maps, legend, north arrow, scale and text inserted and displayed in a frame in Draft mode, only the vector maps are displayed.
Is this a bug?
In the text file with mapping instructions, the instructions for the objects not displayed seem correctly reported.
Thanks in advance
A. Clerici
Anna
Yes, I use the Windows version of GRASS7.0.
The results are correct in .ps and .pdf output. Only in the Preview the raster map is not displayed.
As regards legend, scale, north arrow and text, they are displayed sometimes, but I’m not able to reproduce when and why.
A. Clerici
Da: Anna Petrášová [mailto:kratochanna@gmail.com]
Inviato: sabato 10 ottobre 2015 17:26
A: Aldo CLERICI
Cc: grass-user@lists.osgeo.org
Oggetto: Re: [GRASS-user] wxGUI Cartographic Composer (GRASS 7.0 for Windows)
On Sat, Oct 10, 2015 at 6:40 AM, Aldo CLERICI <aldo.clerici@unipr.it> wrote:
Dear all,
Is this a bug?
do you use Windows? I noticed this problem on this platform, but I haven’t investigated yet. The problem is that the underlying module ps.map creates PostScript file which is difficult to convert into png - we use Python Imaging Library which uses Ghostscript - so the problem with rendering is somewhere there. If you export Postscript file, or PDF file, do you see the result correctly?
Anna
Thanks in advance
A. Clerici
grass-user mailing list
