Hello.
I have some selected lines in a command line script:
#! /bin/sh -x
MYMAPSET=g.gisenv -s get=MAPSET
targetdir=/home/lf/TEMP/
LIST=g.mlist type=rast separator=, pattern="clip_toar*" mapset=$MYMAPSET
echo “$LIST”
i.group group=group input=$LIST
r.out.gdal -c -f input=group format=HFA type=Float32 nodata=0 output=$targetdir/$MYMAPSET.clip_toar.img
g.remove group=group
In wxGUI Graphical Modeler, how can I use the variables inside the commands options? I’m trying using string data type variables
declaring variables
MYMAPSET
default value g.gisenv -s get=MAPSET
targetdir
default value /home/lf/TEMP/
then using in r.out.gdal options
r.out.gdal -c -f input=group format=HFA type=Float32 nodata=0 output=%targetdir/%MYMAPSET.clip_toar.img
or
Without results.
Anyone have ideas how to solve this problem? Is it possible in Graphical Modeller?
Thank you.
Luís Ferreira
