[GRASS-user] wxGUI: new column doesn't appear in properties
Hi to all
in wxGui (grass6.5.svn):
1)load a vector map in Layer manager;
2)show attribute table -> manage tables -> add a new column and close
the window;
3)in layer manager, select the vector map, properties->labels->name of
column to be displayed: the new column isn't in drop-down list.
The same also in the case you insert some values in the new field.
Are there any ways to refresh the list of fields without remove the
vector map from layer manager and reload it?
Paolo C.
Lat. 44° 39' 11.08'' N Long. 7° 23' 25.26'' E
2009/4/21 Paolo Craveri <pcraveri@gmail.com>:
the window;
Fixed in r36835.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
