[GRASS-user] wxNviz: decorations do not have any explanatory text and need 2D raster
Trying to add some decorations (scalebar and North arrow) to 3D visualisations, I noticed the following:
- Without a 2D raster map, no decorations appear. You have to display a 2D raster map, add decorations and then, if you do not want to visualize the 2D raster (e.g. because you just want to see a series of slices in a 3D raster you can uncheck the 2D raster in the Layers tab. Why the need for a 2D raster ? Are the two decorations defined based on that raster ?
- Both decorations are without any annotation (no text indicating the length of the scale bar, no N on the arrow). Is this me missing something, or is this the way they work ?
Moritz
On Wed, Dec 7, 2016 at 5:16 AM, Moritz Lennert
<mlennert@club.worldonline.be> wrote:
Yes, the position is based on the surface. It could be changed I
suppose, but that's obviously more work.
The text have not been working for a long time. Rendering text in
opengl is not trivial as I realized when I was looking into that
several years ago.
Anna
Moritz
grass-user mailing list
grass-user@lists.osgeo.org
