On Mon, 1 May 2023, Anna Petrášová wrote:
The error comes from this:
from numpy import matrix
Is it possible you have different Python installations on your computer?
Try running a python shell from an active GRASS session and running the
import command and see what it gives you.
Anna,
Apparenly so. My Slackware64-15.0 includes python2-2.7.18, python3-3.9.10, and
python3-numpy-1.22.3. No python2-numpy.
Will GRASS be moving to Python3 some time?
Rich
You are likely using Python 3 already. Why don’t you try to see which one you use as I suggested?
On Mon, May 1, 2023 at 11:42 AM Rich Shepard <rshepard@appl-ecosys.com> wrote:
Anna,
Rich
grass-user mailing list
grass-user@lists.osgeo.org
You are likely using Python 3 already. Why don't you try to see which one
python3-3.9.10, and python3-numpy-1.22.3. No python2-numpy.
Anna, As I wrote: python3-3.9.10 and python3-numpy-1.22.3 are installed,
along with python2 and the last python2-numpy.
Rich
When you run GRASS, go to terminal, type “python”, press Enter and look what the version of Python you use:
GRASS nc_spm_08_grass7/testpatch:~ > python
Python 3.8.10 (default, Mar 13 2023, 10:26:41)
[GCC 9.4.0] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
import numpy as np
np.version.version
‘1.17.4’
or in the GUI, go to Python shell tab, look at the Python version, and try importing numpy
On Mon, May 1, 2023 at 12:43 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
Rich
When you run GRASS, go to terminal, type "python", press Enter and look
Anna,
It's the 2.7.18 version. Is there a configuration file in which I can
specify python3?
Rich
There is GRASS_PYTHON:
https://grass.osgeo.org/grass82/manuals/variables.html
But I have never used it myself. Note that we don’t support Python 2 anymore.
On Mon, May 1, 2023 at 1:42 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
Anna,
It’s the 2.7.18 version. Is there a configuration file in which I can
specify python3?
Rich
But I have never used it myself. Note that we don't support Python 2
anymore.
Anna,
Then I wonder why this clean 15.0 installation on the ThinkPad didn't
automatically use python3. Guess I'll add the environmenal variable to my
.bash_profile.
Rich
You may want to change the default Python on your system.
On Mon, May 1, 2023 at 2:14 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
anymore.
Anna,
Then I wonder why this clean 15.0 installation on the ThinkPad didn’t
automatically use python3. Guess I’ll add the environmenal variable to my
.bash_profile.
Rich
