I'm playing with the new gui. I've tried it yesterday for the first
time: it rocks!
There are some warning and little errors the come raised with some
tasks, but everything seems to work fine.
The first error I've experimented is:
23:57:44: Can not enumerate files in directory
'/home/giova/.kde/share/mimelnk/text' (error 13: Permesso negato)
23:57:46: Can not enumerate files in directory
'/home/giova/.local/share/applications' (error 13: Permesso negato)
It happens when I launch d.vect or d.rast the very first time. I click
ok and the d.vect (d.rast) window opens correctly. The subsequent
times I do it, it doesn't happen...
As Martin Landa has suggested me, it's a problem related to wxpython
and KDE, not Grass.
Giovanni
2008/2/25, G. Allegri <giohappy@gmail.com>:
time: it rocks!
and KDE, not Grass.
Giovanni
> Hi,
> time: it rocks!
> Great work!
> Thanks,
> Giovanni
grass-user mailing list
grass-user@lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/grass-user
Using wx.LogNull() has solved the problem.
I've added it both in wxgui.py and menuform.py, gust before
app.MainLoop() in the main routine.
The GUI appears to load faster too...
Giovanni
2008/2/25, Martin Landa <landa.martin@gmail.com>:
Ciao,
can you try to add
wx.LogNull()
instance to wxgui.py (launch d.vect/d.rast from GUI) or menuform.py
(launch for CLI)?
> and KDE, not Grass.
> Giovanni
> > Hi,
> > time: it rocks!
> > Great work!
> > Thanks,
> > Giovanni
- before app.MainLoop inside wxgui.py
- before GrassGUIApp( task ).MainLoop() inside menuform.py
Giovanni
> Ciao,
> can you try to add
> wx.LogNull()
> (launch for CLI)?
> See
> http://aspn.activestate.com/ASPN/Mail/Message/wxPython-users/3609948
> Regards, Martin
> > and KDE, not Grass.
> > Giovanni
> > > Hi,
> > > time: it rocks!
> > > Great work!
> > > Thanks,
> > > Giovanni
> > _______________________________________________
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
