[GRASS-user] wxpython gui in ubuntu
Hello everybody,
using the freshly built grass 6.3 and 7 from the last svn source in Ubuntu I recognized two problems. The first one appearing when I start the wxpytthon gui:
  GRASS_VERSION (FERO):~ >
** (python:20314): WARNING **: Can't create printer "PDF" because the id "PDF" is already used
(python:20314): GnomePrintCupsPlugin-WARNING **: The CUPS printer PDF could not be created
(python:20314): GnomePrintCupsPlugin-WARNING **: The data for the CUPS printer PDF could not be loaded.
The next one looks more serious - when I try to open the attribute table using the attribute table manager icon on the gui toolbar I got this errormessage:
"Execution failed: 'db.columns --q driver=pg database=host=localhost,dbname=FERO,port=5432 table=' "
It looks like the icon is not associated with the proper command.
Best regards
tomas
p.s: the OS is Ubuntu Hardy, the database is postgresql.
On Sun, Sep 28, 2008 at 4:52 PM, Tomas Lanczos <lanczos@t-zones.sk> wrote:
Hello everybody,
gui:
not be created
AFAIK this has been fixed in GRASS 6.4, better to use that:
http://trac.osgeo.org/grass/wiki/DownloadSource#GRASS6.4
errormessage:
no idea, sorry,
