Due to the fact that i.class is not available at Windows I decided to start using GRASS on Linux.
I have just installed and compiled. When I start grass64 I get this warning:
“WARNING: Vector digitizer is not available (No module named grass6_wxvdigit). Note that vector digitizer is currently not working under MS Windows (hopefully will be fixed soon). Please try more recent version of GRASS.”
But since I’m now using LINUX :), I don’t give a damn about that.
But unfortunely, in GIS lay Manager “Start Editing” option is not available. And, when I select “Digitizer” at GIS Map Display, I get the following error window
" Unable to start vector digitizer. The VDigit python extension was not found or loaded properly. Switching back to 2D display mode Details: No module named grass6_wxdigit"
What am I missing because it was suppose to be working…
2009/12/18 Luis Lisboa <luislisboa1975@gmail.com>:
"WARNING: Vector digitizer is not available (No module named
grass6_wxvdigit).
(hopefully will be fixed soon). Please try more recent version of GRASS."
But since I'm now using LINUX :), I don't give a damn about that.
But unfortunely, in GIS lay Manager "Start Editing" option is not available.
And, when I select "Digitizer" at GIS Map Display, I get the following
error window
What am I missing because it was suppose to be working..
Thanks and happy holidays for everyone.
Ok when I run SVN I used this command
./configure --enable-64bit --with-libs=/usr/lib64 --with-wxwidgets --with-blas --with-lapack
So, I have to add: --with-cxx.
And then I have to compile those 2. I just have to run Makefile of the following directories:
…/grass-6.4.svn_src_snapshot_2009_12_12/gui/wxpython/vdigit
…/grass-6.4.svn_src_snapshot_2009_12_12/gui/wxpython/nviz
grass6_wxvdigit).
error window
Also add --with-python switch.
.../grass-6.4.svn_src_snapshot_2009_12_12/gui/wxpython/vdigit
.../grass-6.4.svn_src_snapshot_2009_12_12/gui/wxpython/nviz
Right? Thanks Martin, that was really helpful
Also, --with-wxwidgets is (AFAIK) only meaningful if you also use
--with-python and --with-cxx.
The wxPython GUI gets "built" (i.e. installed) unconditionally. The
configure switches only affect components which contain C/C++ code
which needs to be compiled.
