On Feb 7, 2009, at 10:00 AM, <grass-user-request@lists.osgeo.org> <grass-user-request@lists.osgeo.org > wrote:
Date: Sat, 7 Feb 2009 02:18:45 +0000
Subject: Re: [GRASS-user] xganim tools
To: grass-user@lists.osgeo.org
Message-ID: <18828.61317.47612.985573@cerise.gclements.plus.com>
Content-Type: text/plain; charset=us-asciiMichael Barton wrote:
I tried use xganim for animating a raster files.
http://grass.itc.it/grass62/manuals/html62_user/xganim.htmlwhen I typed xganim, the answer is command not found
It is present in 6.4, but GRASS needs to be built with motif/lesstif
support for xganim to be there.Install the lesstif2-dev package and "./configure --with-motif"
A TclTk replacement for xganim is included in GRASS 6.3 and above. It
is a little nicer than the original and doesn't require motif/lestif.Note that it's part of gis.m, not a standalone program.
In 7.0, the standalone xganim has been re-written using wxWidgets; it
could probably use some testing.--
If it is the module in bin with the same name (i.e, xganim), I tried it and it doesn't work on the Mac at least. It opens and loads the files, but the interface locks up and none of the buttons are responsive.
Michael
