[GRASS-user] zonal statistics for multiple areas
Hello to everybody,
I hope my question is appropriate for this mail list. I have created 5 different buffer layers (d=100,200,300,400,500 m) from a point vector. Now i want to compute some zonal statistics using different rasters as input. I know how to do that separately, but i was wondering how could i automate this procedure using a python script. I know python’s basics, but i was not able to do so following guidelines that i found on the internet, e.g GRASS tutorial. Thank you in advance, A
Hi Alessandro,
You could try v.rast.bufferstats [1], if you do not have hundrets of thousands of points….
If the buffers don`t overlap, you could use v.rast.stats [2] from the upcoming GRASS 7.6 release, that will allow multiple raster input…
Otherwise have a look at the general introduction to GRASS and Python [3].
Stefan
1: https://grass.osgeo.org/grass74/manuals/addons/v.rast.bufferstats.html
2: https://grass.osgeo.org/grass76/manuals/v.rast.stats.html
3: https://grasswiki.osgeo.org/wiki/GRASS_and_Python
Hello to everybody,
Some further python specific tips that might help.
To get a list of rasters that match some pattern (say you have many rasters like “band1”, “band2”,…), then run v.rast.stats on each of them in a loop to get zonal stats in the vector “buffers”:
# This must be run from within a grass session
import grass.script as gscript
rast_list = gscript.read_command("g.list", type = "rast", pattern = "band*").strip().split("\n")
# Loop thru the rasters, run v.rast.stats, and specify the column prefix using the raster name.
methods = ("minimum", "maximum", "average", "sum") # add whatever stats you need
for r in rast_list:
gscript.run_command("v.rast.stats",
map_ = "buffers", raster=r, column_prefix=r, method=methods)
Be aware that if you have many rasters, you’ll end up with many,many columns in the “buffers” vector
On 10/29/18 9:54 PM, Stefan Blumentrath wrote:
Hi Alessandro,
Stefan
From: grass-user grass-user-bounces@lists.osgeo.org On Behalf Of Alessandro Sebastiani
Sent: mandag 29. oktober 2018 16:06
To: grass-user@lists.osgeo.org
Subject: [GRASS-user] zonal statistics for multiple areas
Hello to everybody,
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
thank you all for your suggestions.
Dear Nikos, I have some 0-1 rasters that represents presence-absence of different land covers. Each raster’s resolution is 10x10m, thus i want to compute the sum in order to obtain the surface covered by each land cover within my buffers. As regards to the buffer, i want to use the 0-100, 0-200, 0-300, 0-400 and 0-500 for computing stats. I can do it separately with the module v.rast.stats. I just don’t know how to loop it in a python script
Dear Stefan, thank you, i guess that using multiple rasters as input would be a good solution. however i would really like to loop it using a python script since that would be useful in other situation that i’m going to face in the next days
Dear Micha thank you, i’ll try ASAP!
Il giorno lun 29 ott 2018 alle ore 21:07 Micha Silver <tsvibar@gmail.com> ha scritto:
for r in rast_list:
Hi Alessandro,
Stefan
Hello to everybody,
Micha Silver
Ben Gurion Univ.
Resending, as I forgot to Cc the list.
* Alessandro Sebastiani <alessandro.sebastiani@uniroma1.it> [2018-10-29 16:05:54 +0100]:
Hello to everybody,o
Hello Alessandro,
You are in the right place. And the first guess is that what you need to
do is not difficult using GRASS GIS.
Which rasters exactly? Would you want to use as base maps each of the
'0 to 100 m', '100 to 200 m' and so on "buffers" or '0 to 100 m', '0
to 200 m' and so on up to '0 to 500 m'? And then, the 'other' maps
would be the 'cover' map, each time?
If you share exactly what you need to do, i.e. in form of an algorithm
using pseudo-syntax, it will be easier to understand and potentially
suggest ways to get this done.
For example:
for each Buffer in Buffers:
    compute zonal statistics using base=Buffer and cover=RasterX ```
For example, you might be able to get part of this done using raster maps
only and `r.mapcalc` expressions, without the need to construct many loops and
require an extra step in the end to patch maps together.
If you write down the way to do it separately, then you are just few
steps away in looping over your input rasters. The key point is,
obviously, to express what is to be done in an unambiguous way.
I know python's basics, but i was not
tutorial.
Please share which guidelines, i.e. which GRASS GIS tutorial you refer
to.
Nikos
* Alessandro Sebastiani <alessandro.sebastiani@uniroma1.it> [2018-10-29 21:32:51 +0100]:
different land covers. Each raster's resolution is 10x10m, thus i want to
with the module v.rast.stats. I just don't know how to loop it in a python
script
Dear Alessandro,
I don't have time to write back as I would like. Instead, I will send
you off-list some unpublished script. With a bit of reading, there, you
might identify some ideas that will eventually help in what you are
doing.
Kind regards, Nikos
Thanks a lot for your help!
Il giorno mar 30 ott 2018 alle ore 11:49 Nikos Alexandris <nik@nikosalexandris.net> ha scritto:
script
Dear Alessandro,
I don’t have time to write back as I would like. Instead, I will send
doing.
Kind regards, Nikos
Dear all, i was able to compute zonal statistics for multiple areas using this script. I used
v_list = gscript.read_command(“g.list” , type = “vect”).strip().split(“\n”)
i have 5 vectors in my list
method = (“sum” , “average”)
for v in v_list:
gscript.run_command(“v.rast.stats”, map_=v, raster = “LC1”, column_prefix = “LC1”, method = methods)
Now i have like 4 rasters that i would like to use as input to compute my statistics. Is there a way to loop this process for rasters and vector at the same time? i tried creating a list for rasters and using the name list as raster input but it seems not to work! cheers, Alessandro
Il giorno mar 30 ott 2018 alle ore 11:52 Alessandro Sebastiani <alessandro.sebastiani@uniroma1.it> ha scritto:
script
Dear Alessandro,
doing.
Kind regards, Nikos
> v_list = gscript.read_command("g.list" , type = "vect").strip().split("\n")
# i have 5 vectors in my list
> method = ("sum" , "average")
> for v in v_list:
> gscript.run_command("v.rast.stats", map_=v, raster = "LC1", column_prefix = "LC1", method = methods)
What exactly did you try? There should not be any problem to do nested loops. i.e.:
r_list = gscript.read_command("g.list" , type = "rast", pattern="LC*").strip().split("\n")
for v in v_list:
for r in r_list:
map_=v, raster = r, column_prefix = r, method = methods)
Il giorno mar 30 ott 2018 alle ore 11:52 Alessandro Sebastiani <alessandro.sebastiani@uniroma1.it <mailto:alessandro.sebastiani@uniroma1.it>> ha scritto:
        <mailto:alessandro.sebastiani@uniroma1.it>> [2018-10-29
        21:32:51 +0100]:
        >thank you all for your suggestions.
        >Dear Nikos, I have some 0-1 rasters that represents
        presence-absence of
        >different land covers. Each raster's resolution is 10x10m,
        thus i want to
        >compute the sum in order to obtain the surface covered by
        each land cover
        >within my buffers. As regards to the buffer, i want to use
        the 0-100,
        >0-200, 0-300, 0-400 and 0-500 for computing stats. I can do
        it separately
        >with the module v.rast.stats. I just don't know how to loop
        it in a python
        >script
        Dear Alessandro,
        will send
        there, you
        you are
        doing.
        Kind regards, Nikos
Micha Silver
Ben Gurion Univ.
I was trying with nested loops and it seems not to be working. Now I tried again (more carefully i have to say) and it worked! Thanks to everybody!
Il giorno mer 31 ott 2018 alle ore 21:55 Micha Silver <tsvibar@gmail.com> ha scritto:
for v in v_list:
loops. i.e.:
r_list = gscript.read_command(“g.list” , type = “rast”,
pattern=“LC*”).strip().split(“\n”)
for v in v_list:
for r in r_list:
mailto:[alessandro.sebastiani@uniroma1.it](mailto:alessandro.sebastiani@uniroma1.it)> ha scritto:
<nik@nikosalexandris.net mailto:[nik@nikosalexandris.net](mailto:nik@nikosalexandris.net)> ha scritto:
presence-absence of
thus i want to
each land cover
the 0-100,
it separately
it in a python
script
Dear Alessandro,
will send
there, you
you are
doing.
Kind regards, Nikos
Micha Silver
Ben Gurion Univ.
