[GRASS-user] zonal statistics/metrics - beyond simple statistics
Dear GRASS list,
I am developing a Python script to be able to calculate (virtually any) metrics or statistics for zones/polygons in a vector - in analogy to zonal statistics (such as v.rast.stats).
The idea is that one can calculate raster-based metrics (such as proportion of habitat, number of patches, or any metric that can be formalized as a function that takes some information from the input raster and returns a value) for each polygon in the vector, and this is updated as a value in a newly created column in the attribute table of this vector.
Is there already anything like that (some addon/module) that I am missing, just to avoid re-doing something already created?
If not, what I am doing is to create a loop over all the features in a vector, and for each one I zoom and use the polygon to define a mask (using r.mask), so that the calculation of the selected metric is performed only over that polygon, and this process is repeated.
The script allows one to calculate metrics/statistics for multiple raster maps at once, and to incorporate other function for statistics also. It may be found here:
https://github.com/LEEClab/GeneralizedZonalStats
For small vectors this works nicely and I believe it has a great potential. However, when I try to calculate metrics for a large dataset (e.g. the Brazilian map of cities, with almost 6,000 polygons) - and that is when the tool would be interesting -, the process of creating each mask takes too long (387 steps), and the tool becomes kind of useless.
Then I have two questions:
  • First, what drives the number of steps GRASS takes to create a mask? Why it is very small for some maps but very large for others? I quite don’t understand that yet.
  • Do you think of a easier or faster way of doing the same thing (instead of using masks)? v.rast.stats seems to use r.univar and the option ‘zones’ for doing so, but then one gets restricted to the statistics calculated by this module.
Any help or comment would be very welcome!
Best,
Bernardo Niebuhr
Bernardo Santos wrote
Dear GRASS list,
statistics (such as v.rast.stats).The idea is that one can calculate
performed only over that polygon, and this process is repeated.The script
found here:https://github.com/LEEClab/GeneralizedZonalStats
Then I have two questions:- First, what drives the number of steps GRASS
for others? I quite don't understand that yet.- Do you think of a easier
v.rast.stats seems to use r.univar and the option 'zones' for doing so,
Best,Bernardo Niebuhr
grass-user mailing list
grass-user@.osgeo
have look at
https://grass.osgeo.org/grass74/manuals/addons/v.habitat.dem.html
where I've coded some DEM derived stats and characteristics for polygones.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
Hei Bernardo,
Just for the record: I am currently working on something similar / related.
First of all I would like to improve speed of v.rast.stats for multiple inputs:
https://www.mail-archive.com/grass-dev@lists.osgeo.org/msg52562.html and
https://trac.osgeo.org/grass/ticket/3523
Adding a functionality to "tabulate areas" or "count categories" is a next step I have in mind which I am working on in v.rast.bufferstats (will be a port of v.what.rast.buffer [1] to GRASS 7 / pygrass (with some enhancements)). Once I have a good solution there I would like to see if it can be moved to v.rast.stats. Support for dbf driver is however a challenge...
I will add my "work in progress" script to github, so you can have a look if you like.
Stefan
1: https://grass.osgeo.org/grass64/manuals/addons/
-----Original Message-----
From: grass-user <grass-user-bounces@lists.osgeo.org> On Behalf Of Helmut Kudrnovsky
Sent: mandag 9. april 2018 23.19
To: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] zonal statistics/metrics - beyond simple statistics
Dear GRASS list,
to zonal statistics (such as v.rast.stats).The idea is that one can
It may be found here:https://github.com/LEEClab/GeneralizedZonalStats
very large for others? I quite don't understand that yet.- Do you
grass-user@.osgeo
have look at
best regards
Helmut
Hi Helmut and Stefan,
thanks for sharing that with me, it is good to know that there are similar ongoing approaches to solve related issues.
Helmut,
very nice addon. However, it seems to me that the part on calculating statistics is still based on v.rast.stats, am I right?
Stefan, the question you pose is indeed very related. I took a better look at my code and I noticed that what really takes time is not the process of making a mask, but what comes before: the rasterization of one of the polygons of the input vector.
What I do is:
  1. g.region using the vector layer, aligning it to the first of the input rasters
  2. v.to.rast selecting only one of the polygons at a time from the vector layer
  3. r.mask using the rasterized polygon
  4. g.region zoom=rasterized_polygon
  5. calculate any function for all raster maps (in principle using a loop), using this small region and the mask, and attaching the results to the attribute table
  6. repeat 1-5 for all polygons in the input vector
However, I noticed now that what takes time is v.rast.stats, since it depends on the whole region selected, which in my case is much bigger than a single polygon (the vector is a set of ~6,000 small polygons).
Do you guys know if there is a way of using a single polygon from a vector to define the region using something like g.region?
[this would be really great!!]
something like
g.region vector=vector_of_interest cat=1
Best,
Bernardo
Em terça-feira, 10 de abril de 2018 06:01:34 BRT, Stefan Blumentrath Stefan.Blumentrath@nina.no escreveu:
Hei Bernardo,
Adding a functionality to “tabulate areas” or “count categories” is a next step I have in mind which I am working on in v.rast.bufferstats (will be a port of v.what.rast.buffer [1] to GRASS 7 / pygrass (with some enhancements)). Once I have a good solution there I would like to see if it can be moved to v.rast.stats. Support for dbf driver is however a challenge…
I will add my “work in progress” script to github, so you can have a look if you like.
Stefan
Dear GRASS list,
  • and that is when the tool would be interesting -, the process of
    very large for others? I quite don’t understand that yet.- Do you
grass-user@.osgeo
have look at
where I’ve coded some DEM derived stats and characteristics for polygones.
best regards
Helmut
Hi Bernado,
Please find attached the «work-in-progress» version of v.rast.bufferstats for some more inspiration.
v.db.select -r does what you are looking for:
https://grass.osgeo.org/grass74/manuals/v.db.select.html
However, if the polygons you are working with don`t overlap, looping should not be required, and you should be able to use r.univar with zones or r.stats for all polygons at once…
Stefan
(attachments)
v.rast.bufferstats.py (13.6 KB)
From: Bernardo Santos bernardo_brandaum@yahoo.com.br
Sent: onsdag 11. april 2018 20.59
To: Helmut Kudrnovsky hellik@web.de; grass-user@lists.osgeo.org; Stefan Blumentrath Stefan.Blumentrath@nina.no
Helmut,
What I do is:
something like
Best,
Bernardo
Em terça-feira, 10 de abril de 2018 06:01:34 BRT, Stefan Blumentrath <Stefan.Blumentrath@nina.no> escreveu:
Hei Bernardo,
Stefan
Dear GRASS list,
grass-user@.osgeo
have look at
best regards
Helmut
Helmut,
What I do is:
1) g.region using the vector layer, aligning it to the first of the input rasters
2) v.to.rast selecting only one of the polygons at a time from the vector layer
3) r.mask using the rasterized polygon
You can actually use r.mask directly with the vector map using the vector and cat/where parameters.
4) g.region zoom=rasterized_polygon
5) calculate any function for all raster maps (in principle using a loop), using this small region and the mask, and attaching the results to the attribute table
6) repeat 1-5 for all polygons in the input vector
After step 4, your region should be only the size of the rasterized_polygon. If this is not the case there is an issue somewhere. If you use r.mask directly with the vector map you should be able to set the region to the mask using g.region raster=MASK.
something like
g.region does not have cat/where options, but I agree that this might be useful.
More generally, and in support of what Stefan has already said, it might be helpful to get a bigger picture of what exactly you are doing and what your data looks at exactly, as maybe looping is not your best option.
Also, keeping everything in raster and text file realm as long as possible could speed up the process as attribute data handling is often a bottle neck. You can see the code of the i.segment.stats addon [1] for an example of this, including parallelization of the zonal statistics of the different raster maps.
Moritz
[1] https://trac.osgeo.org/grass/browser/grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py
Hi Stephan,
Some minutes before you sent me this e-mails, I’d just found out about v.db.select -r. It worked and made the process much faster. Thanks for that anyway.
In my case, the polygons do not overlap. Indeed, many things could be done with r.univar, r.stats or a combination of them and their output info. However, my aim was to think about a way of generalizing it, so that we would be able to use many other functions from the raster maps using the same architecture for calculating the zonal statistics/metrics.
For example, I am still not sure how I would use a combination of r.univar/r.stats and some kind of input raster map to produce, say, zonal info of number of habitat patches, structural or functional connectivity, isolation, or other more complex metrics used in landscape ecology.
That’s way I was building something like that, so that we can just write an alternative function using any raster input map that returns the value of one of such metrics, and then use it to calculate them over sets of zones.
Best,
B
PS: thanks for sharing your code! This v.rast.bufferstats seems very useful, and I can think of some very interesting applications of that. I helped a friend to write something similar but using ArcPy as a ArcMap toolbox, and we applied it to some interesting cases in the delimitation of Protected Areas’ buffer zones (but still did not published it). But doing that with a free and open source tool would be much more interesting!
Em quarta-feira, 11 de abril de 2018 18:32:18 BRT, Stefan Blumentrath Stefan.Blumentrath@nina.no escreveu:
Hi Bernado,
Stefan
Helmut,
What I do is:
something like
Best,
Bernardo
Hei Bernardo,
Stefan
Dear GRASS list,
grass-user@.osgeo
have look at
best regards
Helmut
Hi Bernado,
It depends what you consider general. Even if I work with landscape ecology myself, I would assume landscape metrics or functional connectivity to be rather “special” than “general” statistics.
Putting a lot of functionality into one module can be very useful for some cases, but can come with a number of drawbacks as well.
A general Unix concept is to do one thing and do it well, and rather write modular programs that work together than very complex single tools…
Stefan
1: https://en.wikipedia.org/wiki/Unix_philosophy
Sent: torsdag 12. april 2018 16.57
Subject: Re: RE: [GRASS-user] zonal statistics/metrics - beyond simple statistics
Hi Stephan,
Best,
B
Em quarta-feira, 11 de abril de 2018 18:32:18 BRT, Stefan Blumentrath <Stefan.Blumentrath@nina.no> escreveu:
Hi Bernado,
Stefan
From: Bernardo Santos <bernardo_brandaum@yahoo.com.br>
To: Helmut Kudrnovsky <hellik@web.de>; grass-user@lists.osgeo.org; Stefan Blumentrath <Stefan.Blumentrath@nina.no>
Helmut,
What I do is:
something like
Best,
Bernardo
Hei Bernardo,
Stefan
Dear GRASS list,
grass-user@.osgeo
have look at
best regards
Helmut
That's way I was building something like that, so that we can just write an alternative function using any raster input map that returns the value of one of such metrics, and then use it to calculate them over sets of zones.
Have you looked into the landscape metrics modules, notably the r.li suite of modules, but also the r.pi suite in the addons (although ISTR that the latter is not really usable in its current state) ?
Moritz
Hi Stephan,
nice points you raised. I didn’t know about the Unix philosophy, and indeed it seems as a more solid / simple way of building things…
And yeah, I agree that these metrics/statistics I mentioned are not ‘general’ at all.
What I meant by general is that we can write any other function that has one or more raster/vector maps as input, makes some calculation and returns a value, and just use this function as input for this ‘GeneralizedZonalStats’, without having to change anything else…
But yes, I agree that calling that ‘Generalized’ or ‘General’ may not be the best option…
Best,
Bernardo
Em quinta-feira, 12 de abril de 2018 12:18:20 BRT, Stefan Blumentrath Stefan.Blumentrath@nina.no escreveu:
Hi Bernado,
Stefan
Hi Stephan,
Best,
B
Hi Bernado,
Stefan
Helmut,
What I do is:
something like
Best,
Bernardo
Hei Bernardo,
Stefan
Dear GRASS list,
grass-user@.osgeo
have look at
best regards
Helmut
Hi Moritz,
thanks for the comments.
I didn’t know that r.mask had a ‘cat’ option, this makes the whole process more direct. The same for using g.region raster=MASK.
Also, the hint about keeping info as text (as you did in i.segment.stats) and raster is a very good idea to make the process faster. I’ll implement those things to speed up the code.
I don’t know if it makes it clearer, but what we wanted is to calculate several metrics and statistics, using Brazilian city limits as zones (a total of ~5,600 cities), based on land use maps for the whole country (resolution = 30m), for all years from 2000 to 2016. Also, we didn’t wanted to calculate only general/basic statistics such as average, sum, etc., but also more specific metrics such as the area and percentage of different cover classes, edge amount, number of forest patches, isolation between forest patches and others.
That’s why I chose to build it in a way we write a given function (that calculated any of these metrics) and then we use it as an argument for the process, so that we loop over polygons and over input rasters to calculate these metrics for each city.
That was my initial aim, but I guess this may also be useful in other cases.
I know r.li (but didn’t tested r.pi yet), the metrics it calculates are very interesting but somehow limited (of course I could write other ones based on the r.li.daemon core function, but I am not very well versed in C to use it yet…). Even though, I agree I could use maybe a combination of r.li and make some calculations with the output info of r.univar and r.stats to get the same numbers, and maybe I would be able to avoid loops.
I’ll think about it.
Thanks, Moritz and Stephan!
Bernardo
Em quinta-feira, 12 de abril de 2018 13:15:17 BRT, Moritz Lennert mlennert@club.worldonline.be escreveu:
ecology.
sets of zones.
Moritz
