GRASS, VAX and ULTRIX
I am looking fo GRASS distributor for ULTRIX.
Does anyone have any experiences with GRASS on VAX machines (I have
VAXstation 3600)?
Thanks in advance,
        Silvo
      kink@ijs.ac.mail.yu
Centre of Scientific Research of the Slovene Academy of Sciences and Arts
Silvester Kink Novi trg 5 61000 Ljubljana Slovenija
Silvo,
In case no one else tells you, CWU distributes Ultrix GRASS.
try
David Satnik (509) 963-1446
  SATNIKDB%CWU.BITNET@CORNELLC.cit.cornell.edu
for info.
I am running GRASS on a DECstation under ULTRIX. I got the source codes over
ftp and unpacked and built them. Problems did occur in the make operations,
occasionally. If I remember correctly, the most frequent problem was that those
make rules which had a comment line starting with a tab within the rule were
confusing-- I changed these to a comment followed by a tab and they went through.
Good luck,
Joe Vaughan
jkv@air.atmo.arizona.edu
Inst. of Atmo. Phys., U of Arizona. Tucson, AZ
