Grass vector to arcview shape files
Hello grass hoppers,
Is there a way to convert grass vector files to arcview
shape files. I know D'Avello developed a script to
create "world" file and "header" file for
display in ArcView from the cellhd.
In the back of my mind (where is that?) I remember someone
made something for this task but looking through my grass mail files,
I couldn't grep any hint.
Any comments?
Alejandro Hinojosa
Any comments?
Alejandro Hinojosa
Hi
I have recently started using GRASS in a project which creates
isogradient (slope) polygons in grass as native GRASS `dig' files. I need
to import these then into ArcView, and this is how I do it.
Export GRASS vector file with
v.out.dlg input=<infile> output=<out.dlg>
Then in ArcView (this is v3.1 for Windows, but I believe it will work in
Unix versions too) - use the Dlg20a.ave script to import the DLG file.
You can get this script from ESRI's site if you don't have it. It is I
believe in dlg2shp.zip.
You might want to edit the imported to file to remove the matte and
`external' polygons ie. with Major1=0 (normal data has Major1=999 by
default) and then perhaps the Major1 field itself.)
Hope this helps
DD Gray
