Hello,
As promised, I've attached some C code that converts GRASS ASCII vector lines
(not polygons) into MapInfo's .mif/.mid ASCII format. It's here for anybody to
hack about to their hearts content.
At the moment it only converts into the British National Grid projection - whose
parameters are hard coded into the programme. Also the input and output
filenames and paths are hard coded as #defines.
I've put quite a lot of notes in the code - so hopefully it shouldn't be to much
hassle to hack.
Hope it's of use to some people. Keep me informed of any updates people make.
Cheers, Al.
_____________________ cut here ___________________________________________
/*** vect2mif.c programme that converts GRASS ASCII vector ***/
/*** file (with lines only) into MapInfo mif/mid ***/
/*** ASCII transfer format, retaining attributes. ***/
/*** v.1.0 Thurs. 4th June '97, Alastair Duncan, Environment Agency, UK ***/
#include <stdio.h>
#include <string.h>
/****------ DEFINE INPUT AND OUTPUT FILE PATHS AND NAMES ----****/
/*** THESE SHOULD BE KEYBOARD INPUT ARGUMENTS IN FINAL VERSION ****/
/*** First GRASS ASCII file - vector and attribute ***/
#define DIGIN "/home8/grass/uk/lidar/dig_ascii/area9.sub.cont"
#define ATTIN "/home8/grass/uk/lidar/dig_att/area9.sub.cont"
/*** Then MapInfo ASCII file - vector .mif and attribute .mid ***/
#define MIFOUT "/home5/AlsJunk/lidar/area9sub.mif"
#define MIDOUT "/home5/AlsJunk/lidar/area9sub.mid"
/****------------------------- MAIN ---------------------------****/
main()
/***---- DECLARE VARIABLES ----***/
FILE *fptr_digin, /*** input pointers - GRASS dig_ascii file ***/
*fptr_attin, /*** - GRASS dig_att file ***/
*fptr_mifout, /*** output pointers- MapInfo .mif file ***/
*fptr_midout; /*** - MapInfo .mid file ***/
int count, /*** counter for loops ***/
nodes; /*** counts number of nodes in line ***/
char line[255], /*** string to read a line of text ***/
coords[255]; /*** string to read a line of coordinates ***/
double x_coord, /*** double precision floats to store ***/
y_coord, /*** coordinates and z value. ***/
elevation;
/***------------------- OPEN INPUT AND OUTPUT FILES --------------------***/
if ( (fptr_digin = fopen(DIGIN, "r") ) == NULL)
fprintf(stderr, "Could not open file"); /*** GRASS dig_ascii **/
if ( (fptr_attin = fopen(ATTIN, "r") ) == NULL)
fprintf(stderr, "Could not open file"); /*** GRASS dig_att **/
fptr_mifout = fopen(MIFOUT,"a"); /*** mif output file **/
fptr_midout = fopen(MIDOUT,"a"); /*** mid output file **/
/***---------------------- WRITING MIF FILE HEADER -------------------***/
/*** following is the heading for British National Grid projection ***/
/*** consult MapInfo manual for other projections, or make dummy ***/
/*** mif/mid file in projection of choice and cut and paste in the ***/
/*** necessary parameters. ***/
fprintf(fptr_mifout, "Version 300\n");
fprintf(fptr_mifout, "Charset \"WindowsLatin1\"\n");
fprintf(fptr_mifout, "Delimiter \",\"\n");
fprintf(fptr_mifout, "CoordSys Earth Projection 8, 79, \"m\", -2, 49,
0.9996012717, 400000, -100000 Bounds (-7845061.1011, -15524202.1641)
(8645061.1011, 4470074.53373)\n");
fprintf(fptr_mifout, "Columns 1\n");
fprintf(fptr_mifout, " Elevation Float\n");
fprintf(fptr_mifout, "Data\n");
fprintf(fptr_mifout, " \n");
/***------- READING ASCII DIG VECTOR FILE AND WRITING MIF FILE --------***/
for(count=1; count <=14; count++)
fgets(line,sizeof(line),fptr_digin); /** this skips past the ***/
/** header of the GRASS ***/
/** dig_ascii file. ***/
do
fgets(line,sizeof(line),fptr_digin); /** this loop reads the dig ***/
if(line[0] = 'L') /** file and writes the mif ***/
sscanf(line, "L %d\n", &nodes);
if(nodes >= 32000)
printf("\n\n\t\tA LINE HAS MORE THAN 32000 NODES\n\n\t\tWILL NOT BE
READ BY MAPINFO\n\n\t\tGENERALISE VECTOR LAYER IN GRASS\n\n");
fprintf(fptr_mifout, "Pline %d\n", nodes);
for(count=1; count <= nodes; count ++)
fgets(coords,sizeof(coords),fptr_digin);
sscanf(coords, " %lf %lf\n", &y_coord, &x_coord);
fprintf(fptr_mifout, "%lf %lf\n", x_coord, y_coord);
fprintf(fptr_mifout, " Pen (1,2,16744448) \n");
while(!feof(fptr_digin));
do /** this loop reads the att ***/
{ /** file and writes the mid ***/
fgets(line,sizeof(line),fptr_attin);
sscanf(line, "L %lf %lf %lf\n", &x_coord, &y_coord, &elevation);
if(!feof(fptr_attin))
fprintf(fptr_midout, "%lf\n", elevation);
while(!feof(fptr_attin));
/***------------------ CLOSING INPUT AND OUTPUT FILES -----------------***/
fclose(fptr_digin);
fclose(fptr_attin);
fclose(fptr_mifout);
fclose(fptr_midout);
