P. Martijn van Leusen writes:
To Craig Anderson's wish list I would like to add:
(lines deleted)
g.remove/g.rename - should issue a warning before removing
or renaming `parents' of reclassified maps.
Here is a temporary solution to the removal problem, in the form of a shell
script that I wrote. It checks for reclasses in *all* mapsets under a Location,
regardless of the search path, so be aware that it can be slow if you have
*lots* of raster map layers. It also gives the option of printing (using lp)
the list of reclassified maps based on a named 'parent' map; you may need to
edit this to suit your particular system.
# ****** r.remove.sh *******
# Written by Malcolm Williamson
# @(#) r.remove.sh: Checks for reclasses before removing a raster map layer.
# Last revision: 3/24/93
if [ "$GISRC" = "" ] ; then
echo "This command must be run from GRASS!"
echo ""
exit 1
fi
name=""
if [ $# = 0 ]; then
g.ask type=old prompt="Enter name of raster file to be removed." element=cell \
desc=raster unixfile=/tmp/$$
. /tmp/$$
rm -f /tmp/$$
if [ "$name" = "" ]; then
exit 0
else
realname="$name"
fi
else
name=$*
for item in $name
do
if [ ! -f $LOCATION/cell/$item ]; then
echo "Raster file $item not found in mapset $MAPSET"
else
realname="$realname $item"
fi
done
fi
mapsets=`ls $LOCATION/..`
for mapname in $realname ; do
reclass=""
clear
echo "Checking for reclasses of $mapname..."
echo ""
for mapset in $mapsets ; do
if [ -d $LOCATION/../$mapset/cellhd ] ; then
rasters=`ls $LOCATION/../$mapset/cellhd`
else
continue
fi
for raster in $rasters; do
pmap=`cat $LOCATION/../$mapset/cellhd/$raster | grep $mapname`
if [ "$pmap" != "" ] ; then
pmapset=`cat $LOCATION/../$mapset/cellhd/$raster | grep $MAPSET`
if [ "$pmapset" != "" ] ; then
reclass="$reclass $raster@$mapset"
fi
fi
done
done
if [ "$reclass" != "" ] ; then
echo ""
echo " **********WARNING************"
echo ""
echo "The following raster map layers are reclasses of $mapname:"
echo ""
for map in $reclass ; do
echo "$map"
done
echo ""
echo "If you remove $mapname, these reclasses will be useless."
echo ""
echo -n "Do you really want to remove $mapname? y/n (n): "
read ans
if [ "$ans" = "y" ] || [ "$ans" = "Y" ] ; then
echo ""
echo "Do you want a printout of the reclasses map layers that"
echo -n "will be effected? y/n (n): "
read ans2
if [ "$ans2" = "y" ] || [ "$ans2" = "Y" ] ; then
echo "Reclassed map layers based on $mapname in $MAPSET:" > /tmp/printfile
echo "$map" >> /tmp/printfile
done
lp /tmp/printfile
sleep 3
rm /tmp/printfile
fi
else
continue
fi
fi
echo ""
g.remove $mapname
done
exit 0
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
