GRASS with LAN
  GRASS runs just fine over the net, keeping the binaries on an
  NFS server. The fifo's have to be on the local machine, though.
  Also, when digitizing, the v.digit binary should be on the local
  machine because devices can't be accessed over the net
Actually the binaries can reside on the NFS server; you will however
have to create a seperate entry for each digitizer with the correct
local port for each (in the etc/digcap file). Each entry in the
digcap file can only be used by one individual at a time therefore
requiring seperate entries for each.
  Martin
Ken Sibley
USDA-SCS/NCG "Hell, if you understand everything I say,
ksibley@ncg.scs.ag.gov you'd be me!" - Miles Davis
