GRASS X monitors
Yes,
we ran into a similar problem and came up with a fix that seemed to solve our
problem but reportedly did not work in all cases.
If you look in $GISBASE/src/display/devices/XDRIVER/XDRIVER/Graph_Set.c you
should see a comment on about line 80 describing the one-line fix that we used.
Cheers!
--john
John Cartwright GIS Analyst
johncc@rover.ftc.nrcs.usda.gov USDA-SCS/MACA
> A problem was recently brought to my attention regarding the use of multiple
> X display monitors in GRASS. When using two or more X display monitors,
> the monitors started after the first one appear normal until an image is
> displayed, at which time the monitor(s) fade to a dull grey and by default
> erases to a dull grey. Images subsequently displayed also appear to have a highly muted colortable. This even happens when the colormode is set to float.
> Has anyone encoutered this problem and/or developed a solution? Any help
> would be appreciated.
> Mark Gibb
> USACERL
Yes, I and many others have had this problem and reported it to the grassu
and grassp lists. I have never seen any reply that offered a solution (at
least not in the past 3 years). I'm sure many Grass users would appreciate
you working on a solution...
Martijn van Leusen
